Salta al contenuto principale
Lenovo ThinkPad T400s LCD Screen Replacement
Cosa ti serve
  1. Lenovo ThinkPad T400s LCD Screen Replacement, LCD Screen: passo 1, immagine 1 di 1
    • Use a #0 Phillips head screwdriver to remove the two 3mm screws that hold the screen bezel in place.
  2. Lenovo ThinkPad T400s LCD Screen Replacement: passo 2, immagine 1 di 1
    • Using the plastic opening tool, gently pry off the plastic LCD screen frame around the entire perimeter.
    • Be careful while prying the frame off, because the plastic tabs that hold it in may break.
  3. Lenovo ThinkPad T400s LCD Screen Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad T400s LCD Screen Replacement: passo 3, immagine 2 di 2
    • Remove the LCD connector by pulling on the ribbon cable at the connection.
  4. Lenovo ThinkPad T400s LCD Screen Replacement: passo 4, immagine 1 di 1
    • Lift the LCD screen out to replace.
    • Make sure to remove the screen with both hands and from opposite edges of the screen.
Conclusione
Altre 7 persone hanno completato questa guida.
Cal Poly, Team 6-18, Maness Spring 2015 Membro di Cal Poly, Team 6-18, Maness Spring 2015
CPSU-MANESS-S15S6G18
4 Membri
5 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 13
Tutti i Tempi: 2,543
