Salta al contenuto principale
Lenovo ThinkPad S431 Hard Disk Drive Replacement
Cosa ti serve
  1. Lenovo ThinkPad S431 Hard Disk Drive  Replacement, Hard Disk Drive: passo 1, immagine 1 di 2 Lenovo ThinkPad S431 Hard Disk Drive  Replacement, Hard Disk Drive: passo 1, immagine 2 di 2
    • Remove the 8 screws that hold down the back panel using the Phillips #000 screwdriver.
  2. Lenovo ThinkPad S431 Hard Disk Drive  Replacement: passo 2, immagine 1 di 1
    • Remove the two M2 x 3 mm, wafer-head, nylon-coated screws that hold down the hard drive assembly using the Phillips #0 screwdriver.
  3. Lenovo ThinkPad S431 Hard Disk Drive  Replacement: passo 3, immagine 1 di 1
    • Pull the hard drive assembly out with backside up.
  4. Lenovo ThinkPad S431 Hard Disk Drive  Replacement: passo 4, immagine 1 di 1
    • Remove the four M3 x 3 mm, flat-head, nylon-coated screws on the side of the hard drive assembly using the Phillips #0 screwdriver.
  5. Lenovo ThinkPad S431 Hard Disk Drive  Replacement: passo 5, immagine 1 di 1
    • Gently, remove the plastic cover with the blue strips.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 11
Tutti i Tempi: 766
