Salta al contenuto principale
Lenovo ThinkPad R61i Hard Drive Replacement
Cosa ti serve
  1. Lenovo ThinkPad R61i Hard Drive Replacement, Gather Materials: passo 1, immagine 1 di 1
    • You will need to have a replacement drive ready. The R61i officially supports SATA I speeds, but if you flash the Middleton's BIOS, you will get the full SATA II speed. If you plan on upgrading to an SSD during this process, I would recommend flashing Middleton's BIOS. Get more information & download links here
  2. Lenovo ThinkPad R61i Hard Drive Replacement, Remove the battery & unplug power adapter: passo 2, immagine 1 di 2 Lenovo ThinkPad R61i Hard Drive Replacement, Remove the battery & unplug power adapter: passo 2, immagine 2 di 2
    • You may need to apply a good amount of force to the levers that hold the battery in place. Mine was especially well stuck, as it was a recently installed aftermarket battery.
  3. Lenovo ThinkPad R61i Hard Drive Replacement, Remove the HDD caddy's cover: passo 3, immagine 1 di 1
    • Locate and remove the #2 philips screw on the hard drive bay cover.
    • Pull the hard drive bay cover straight out. Mine required a good bit of wiggling and force before it came out of the computer.
  4. Lenovo ThinkPad R61i Hard Drive Replacement, Remove the caddy & hard drive: passo 4, immagine 1 di 3 Lenovo ThinkPad R61i Hard Drive Replacement, Remove the caddy & hard drive: passo 4, immagine 2 di 3 Lenovo ThinkPad R61i Hard Drive Replacement, Remove the caddy & hard drive: passo 4, immagine 3 di 3
    • Locate the plastic tab that you will need to use to remove the caddy. I recommend using the iFixit plastic tool to remove this, as most screwdrivers could tear or scratch the plastic or drive caddy.
    • Pull the hard drive and caddy straight out of the machine.
  5. Lenovo ThinkPad R61i Hard Drive Replacement, Remove the rubber sleds from the drive caddy: passo 5, immagine 1 di 2 Lenovo ThinkPad R61i Hard Drive Replacement, Remove the rubber sleds from the drive caddy: passo 5, immagine 2 di 2
    • Remove the two rubber sleds from the drive caddy.
  6. Lenovo ThinkPad R61i Hard Drive Replacement, Remove the hard drive from the caddy: passo 6, immagine 1 di 1
    • Remove the four phillips head screws around the hard drive. Do not lose these, as they will be used to install your new hard drive or SSD!
Conclusione
Congratulations! To re-assemble the device, follow the guide in reverse order.
Sam
Membro da: 02/24/17
666 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 28
Tutti i Tempi: 2,200
