Salta al contenuto principale
Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement
Cosa ti serve
  1. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Remove base cover: passo 1, immagine 1 di 1
    • Remove the 7 screws holding the base cover in place.
    • Remove the base cover.
  2. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Unplug the battery: passo 2, immagine 1 di 1
    • Peel up the insulated sheet from the battery connector.
    • Unplug the battery connector in the direction showed by the arrow.
  3. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Remove the battery screws: passo 3, immagine 1 di 1
    • Remove the two M2 × L4 mm, flat-head screws.
    • Remove the two M2 × L5 mm, flat-head, screws.
  4. Lenovo ThinkPad P1 Gen2 Laptop Battery Replacement, Remove the battery: passo 4, immagine 1 di 1
    • Remove the battery.
Conclusione
To replace the battery & reassemble your device, follow these instructions in reverse order.
Max Kletskov
Membro da: 04/22/20
40.307 Reputazione
16 Guide realizzate
iFixit Membro di iFixit
Staff
136 Membri
17.410 Guide realizzate
3 Commenti
Great Thank you for info
Brad - Replica
Will this battery generate a Bios not authentic battery warning? Other replacement batteries would not charge in my P1 Gen2 ThinkPad.
hello - Replica
Is it compatible for Lenovo Thinkpad P1 Gen1 Type 20MD ?
k2ki - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 71
Ultimi 30 Giorni: 333
Tutti i Tempi: 11,176
