Salta al contenuto principale
Lenovo ThinkPad L440 RAM Replacement
Cosa ti serve
  1. Lenovo ThinkPad L440 RAM Replacement, Battery: passo 1, immagine 1 di 3 Lenovo ThinkPad L440 RAM Replacement, Battery: passo 1, immagine 2 di 3 Lenovo ThinkPad L440 RAM Replacement, Battery: passo 1, immagine 3 di 3
    • Open the laptop to access the power button.
    • Hold the power button in the top right until the computer powers off.
    • Turn the computer over so that the bottom of the computer is facing up
  2. Lenovo ThinkPad L440 RAM Replacement: passo 2, immagine 1 di 1
    • On the left side under the raised surface, move the tab to the left towards the unlocked symbol. Repeat this on the right side and move the tab to the right towards the unlocked symbol.
  3. Lenovo ThinkPad L440 RAM Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad L440 RAM Replacement: passo 3, immagine 2 di 2
    • From the top of the laptop, slide the raised surface away from the rest of the laptop and out of its slot to remove the battery from the computer.
  4. Lenovo ThinkPad L440 RAM Replacement, Back Panel: passo 4, immagine 1 di 2 Lenovo ThinkPad L440 RAM Replacement, Back Panel: passo 4, immagine 2 di 2
    • Loosen the four retainer screws on the bottom of the laptop using a Phillips #0 screwdriver.
    • These four screws are attached to the panel with washers, so they will spin freely when they are loose and will come off with the panel.
  5. Lenovo ThinkPad L440 RAM Replacement: passo 5, immagine 1 di 2 Lenovo ThinkPad L440 RAM Replacement: passo 5, immagine 2 di 2
    • With your fingers, lift up the back panel from the left side.
  6. Lenovo ThinkPad L440 RAM Replacement, RAM: passo 6, immagine 1 di 2 Lenovo ThinkPad L440 RAM Replacement, RAM: passo 6, immagine 2 di 2
    • Pull the tabs on either side of the RAM in opposite directions.
    • Pull the RAM stick up and out.
    • Repeat for the second RAM stick.
Conclusione
Kristen Gismondi
Membro da: 11/12/14
91.943 Reputazione
241 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.434 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 35
