Salta al contenuto principale
Lenovo ThinkPad Helix Screen Replacement
Cosa ti serve
  1. Lenovo ThinkPad Helix Screen Replacement, Screen: passo 1, immagine 1 di 1
    • Using a plastic opening tool or opening pick, gently pry the screen off.
    • If possible, use plastic tools to pry the screen, as the metal tool as shown in the image can potentially damage your device.
    • You will need to use a little bit of force to pry it open. There is little indent that goes around the tablet. You will insert your tool between this indent and pry it open.
    • Once you're able to lift a little bit of the screen away from the tablet, work your way around until screen is separated from tablet. Stop for step two.
  2. Lenovo ThinkPad Helix Screen Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad Helix Screen Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad Helix Screen Replacement: passo 2, immagine 3 di 3
    • Lift the screen up slowly.
    • Once separated, you can not fully take it off due to some cable connections.
    • Open the clips of the ZIF connectors and gently grab the cable to pull it out.
  3. Lenovo ThinkPad Helix Screen Replacement: passo 3, immagine 1 di 1
    • Once the cables are disconnected, remove the screen.
Conclusione
Altre 3 persone hanno completato questa guida.
Gateway, Team S1-G6, Saknee Fall 2019 Membro di Gateway, Team S1-G6, Saknee Fall 2019
GCC-SAKNEE-F19S1G6
4 Membri
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 26
Tutti i Tempi: 1,676
