Salta al contenuto principale
Lenovo ThinkPad Edge E520 Hard Drive Replacement
Cosa ti serve
  1. Lenovo ThinkPad Edge E520 Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Power off and unplug the computer before the start of these steps.
    • Close the laptop lid.
  2. Lenovo ThinkPad Edge E520 Hard Drive Replacement: passo 2, immagine 1 di 2 Lenovo ThinkPad Edge E520 Hard Drive Replacement: passo 2, immagine 2 di 2
    • Flip the computer so that the back is facing upwards.
    • Locate the switch used to release the battery.
    • The switch should be located towards the hinge of the laptop near the battery pack and have a lock icon associated with it.
  3. Lenovo ThinkPad Edge E520 Hard Drive Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad Edge E520 Hard Drive Replacement: passo 3, immagine 2 di 2
    • Slide the switch towards the unlocked lock icon.
    • While holding it in the unlocked position, slide the battery towards the hinge.
    • Fully separate the battery pack from the back of the laptop.
  4. Lenovo ThinkPad Edge E520 Hard Drive Replacement, Back Plate: passo 4, immagine 1 di 2 Lenovo ThinkPad Edge E520 Hard Drive Replacement, Back Plate: passo 4, immagine 2 di 2
    • Flip over the laptop and position it with the battery being furthest away from you.
    • Remove the four screws on the edges of the T-Shaped plate with a Phillips #0 screwdriver.
    • Remove the T-Shaped plate from the back of the computer. It should come off easily if all four aforementioned screws are removed.
    • Screw length 6.35 mm, head 3.175 mm
  5. Lenovo ThinkPad Edge E520 Hard Drive Replacement, Hard Drive: passo 5, immagine 1 di 3 Lenovo ThinkPad Edge E520 Hard Drive Replacement, Hard Drive: passo 5, immagine 2 di 3 Lenovo ThinkPad Edge E520 Hard Drive Replacement, Hard Drive: passo 5, immagine 3 di 3
    • Position the laptop so that the battery compartment is facing away from you.
    • Remove the two bracket screws on the bottom of the hard drive.
    • Gently lift out the hard drive with its bracket still attached.
    • Remove the bracket from the hard drive.
Conclusione
Altre 3 persone hanno completato questa guida.
David Skarbek
Membro da: 03/01/18
271 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 11
Tutti i Tempi: 1,412
