Introduzione
If you need to replace the fan, use this guide to access and remove the fan from this device. For this guide you will need a plastic opening tool, a Phillips #0, #00, and #000 screwdriver. This repair may be needed either as a prerequisite to replacing other parts or in order to fix issues such as frequent, but irregular crashes, error messages, or disappearing or scrambled files.
Cosa ti serve
Use a Phillips #0 screwdriver to remove eight M2 × 3 mm screws near the front opening and scattered across the bottom of the laptop.
Remove three M2x3 mm screws using a Phillips #00 screwdriver from the base of the laptop near the opening.
Remove the two M2 x 3mm securing the the optical drive to the device using a Phillips #000 screwdriver.
Use a Phillips #0 screwdriver to remove the four M2 x 6mm screws connecting the heatsink to the motherboard.
