Salta al contenuto principale
Lenovo ThinkPad E570 Wi-Fi Card Replacement
Cosa ti serve
  1. Lenovo ThinkPad E570 Wi-Fi Card Replacement, Wi-Fi Card: passo 1, immagine 1 di 1
    • Turn the laptop over so that the bottom is facing upwards.
  2. Lenovo ThinkPad E570 Wi-Fi Card Replacement: passo 2, immagine 1 di 1
    • Unscrew two captive 5 mm screws from the back panel of the laptop using a Phillips #00 screwdriver.
    • Carefully remove the back panel.
  3. Lenovo ThinkPad E570 Wi-Fi Card Replacement: passo 3, immagine 1 di 1
    • Carefully remove the black and white coaxial cables that are connected to the chip using an opening tool.
  4. Lenovo ThinkPad E570 Wi-Fi Card Replacement: passo 4, immagine 1 di 1
    • Remove the single 4 mm screw from the Wi-Fi card using a Phillips #0 screwdriver.
  5. Lenovo ThinkPad E570 Wi-Fi Card Replacement: passo 5, immagine 1 di 1
    • When the screw is removed, the chip will pop up at an angle.
    • Carefully grab the chip and pull outward to remove it from the laptop.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 10
Tutti i Tempi: 394
