Salta al contenuto principale
Lenovo ThinkPad E570 Solid State Drive (SSD) Replacement
Cosa ti serve
  1. Lenovo ThinkPad E570 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): passo 1, immagine 1 di 1
    • Turn the laptop over so that the bottom is facing upwards.
  2. Lenovo ThinkPad E570 Solid State Drive (SSD) Replacement: passo 2, immagine 1 di 1
    • Unscrew two captive 5 mm screws from the back panel of the laptop using a Phillips #00 screwdriver.
    • Carefully remove the back panel.
  3. Lenovo ThinkPad E570 Solid State Drive (SSD) Replacement: passo 3, immagine 1 di 2 Lenovo ThinkPad E570 Solid State Drive (SSD) Replacement: passo 3, immagine 2 di 2
    • Remove the single 5 mm screw using a Phillips #00 screwdriver.
    • Lift off the SSD carefully.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 39
Tutti i Tempi: 1,035
