Salta al contenuto principale
Lenovo Tab 2 A8 Front-Facing Camera Replacement
Cosa ti serve
  1. Lenovo Tab 2 A8 Front-Facing Camera Replacement, Removing the Back Panel: passo 1, immagine 1 di 3 Lenovo Tab 2 A8 Front-Facing Camera Replacement, Removing the Back Panel: passo 1, immagine 2 di 3 Lenovo Tab 2 A8 Front-Facing Camera Replacement, Removing the Back Panel: passo 1, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Place the tablet face down on a soft, stable surface that will protect the screen.
    • Next, Scrape off the seal over the screw in the back of the tablet with a Metal Spudger.
    • Use the Phillips #000 Screwdriver to remove the M1.4 × 2.5 screw.
    • If the seal covering the screw has already been removed, please proceed to the next step in the process.
    • As the screw is small, you may wish to extract it using a pair of tweezers.
  2. Lenovo Tab 2 A8 Front-Facing Camera Replacement: passo 2, immagine 1 di 3 Lenovo Tab 2 A8 Front-Facing Camera Replacement: passo 2, immagine 2 di 3 Lenovo Tab 2 A8 Front-Facing Camera Replacement: passo 2, immagine 3 di 3
    • Starting on the side, work your way around the the tablet to pop off the back cover. You will want to utilize a metal Spudger for this.
    • Some force may be required initially to pry the back cover off.
    • Note that the button tabs for this device are loose inside the case and will fall out when opening.
  3. Lenovo Tab 2 A8 Front-Facing Camera Replacement, Front-Facing Camera: passo 3, immagine 1 di 1
    Compra
    • Using tweezers, peel off the anti-static sticker from the camera connection port.
  4. Lenovo Tab 2 A8 Front-Facing Camera Replacement: passo 4, immagine 1 di 1
    • Lift the camera out of its socket in the motherboard. Then, using tweezers to grasp the camera connector, carefully pull the connector horizontally out of the port.
    • Be aware that the camera connector will be firmly lodged in the port. When successfully removed, the top side of the port pops up.
  5. Lenovo Tab 2 A8 Front-Facing Camera Replacement: passo 5, immagine 1 di 1
    • Using tweezers to grasp the camera connector, lift the camera out of its socket.
Conclusione
Altre 3 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 1,035
