Introduzione
This guide demonstrates in detail the process of replacing the motherboard. No major technical background necessary for replacement.
Cosa ti serve
Starting at any point along the seam of the case carefully pry it open with the metal spudger, slowly working your way around the outside until the case can come apart.
Use a plastic opening tool or a tweezer to remove any tape.
Unplug the electrical connectors by lifting the clip that hold them in place.
Un commento
I may do this, however, I need to know is this a fix for a Lenovo that won’t charge?
I addend a new battery and the Lenovo doesn’t seem to charge or turn on, is a new Motherboard then necessary?
