Salta al contenuto principale
Lenovo Tab 2 A7-20F Motherboard Replacement
Cosa ti serve
  1. Lenovo Tab 2 A7-20F Motherboard Replacement, Case: passo 1, immagine 1 di 2 Lenovo Tab 2 A7-20F Motherboard Replacement, Case: passo 1, immagine 2 di 2
    • Starting at any point along the seam of the case carefully pry it open with the metal spudger, slowly working your way around the outside until the case can come apart.
  2. Lenovo Tab 2 A7-20F Motherboard Replacement, Battery: passo 2, immagine 1 di 2 Lenovo Tab 2 A7-20F Motherboard Replacement, Battery: passo 2, immagine 2 di 2
    • The battery is connected to the motherboard by the thin wire shown here.
    • Pull up gently on the yellow tape to access the connector.
  3. Lenovo Tab 2 A7-20F Motherboard Replacement: passo 3, immagine 1 di 1
    • Gently detach the connector from the motherboard by pulling up on it.
  4. Lenovo Tab 2 A7-20F Motherboard Replacement: passo 4, immagine 1 di 3 Lenovo Tab 2 A7-20F Motherboard Replacement: passo 4, immagine 2 di 3 Lenovo Tab 2 A7-20F Motherboard Replacement: passo 4, immagine 3 di 3
    • There is double-sided tape inside the case.
    • Use the spudger tool to loosen the bond of the adhesive from the double sided tape.
    • Separate the battery from the case.
  5. Lenovo Tab 2 A7-20F Motherboard Replacement, Motherboard: passo 5, immagine 1 di 3 Lenovo Tab 2 A7-20F Motherboard Replacement, Motherboard: passo 5, immagine 2 di 3 Lenovo Tab 2 A7-20F Motherboard Replacement, Motherboard: passo 5, immagine 3 di 3
    • Use a plastic opening tool or a tweezer to remove any tape.
    • Unplug the electrical connectors by lifting the clip that hold them in place.
    • ''Use the plastic tools first before any metal ones since they can damage the motherboard easily'.'
  6. Lenovo Tab 2 A7-20F Motherboard Replacement: passo 6, immagine 1 di 2 Lenovo Tab 2 A7-20F Motherboard Replacement: passo 6, immagine 2 di 2
    • Remove the three 2.0mm screws using the Phillips #00 Screwdriver bit.
    • These screws are very small and can be lost easily. The black strip at the top of the motherboard is the speaker and the screws can be placed on that because it is magnetic.
  7. Lenovo Tab 2 A7-20F Motherboard Replacement: passo 7, immagine 1 di 3 Lenovo Tab 2 A7-20F Motherboard Replacement: passo 7, immagine 2 di 3 Lenovo Tab 2 A7-20F Motherboard Replacement: passo 7, immagine 3 di 3
    • There are two twisted pairs of wires on the left and right edges of the case.
    • Use a plastic opening tool or tweezers to remove the twisted pairs that are held in place by retaining tabs.
    • These wires lead to objects that need to be carefully lifted from their enclosures at the base of the case using tweezers.
  8. Lenovo Tab 2 A7-20F Motherboard Replacement: passo 8, immagine 1 di 3 Lenovo Tab 2 A7-20F Motherboard Replacement: passo 8, immagine 2 di 3 Lenovo Tab 2 A7-20F Motherboard Replacement: passo 8, immagine 3 di 3
    • After taking out the twisted pairs, there is still one more strip that needs to be removed. It is located off the side of the motherboard and is the piece that receives input for volume and power.
    • Gently lift up the motherboard starting from the right side. The final strip can be removed by gently pulling it up from the case.
    • Remove the motherboard completely from the back panel.
Conclusione
Un commento
I may do this, however, I need to know is this a fix for a Lenovo that won’t charge?
I addend a new battery and the Lenovo doesn’t seem to charge or turn on, is a new Motherboard then necessary?
millonthefloss08 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 6
Tutti i Tempi: 1,471
