Introduzione
Before removing the battery, make sure that the device is totally shut off and the charger is disconnected. Also, make sure that your hands are dry and you have discharged any built up static charge by touching a good ground to avoid damaging any electric components.
Strumenti
Parti
Nessuna parte specificata.
Starting at any point along the seam of the case carefully pry it open with the metal spudger, slowly working your way around the outside until the case can come apart.
Altre 2 persone hanno completato questa guida.
