Salta al contenuto principale
Lenovo Tab 2 A10-70 Rear Facing Camera Replacement
Cosa ti serve
  1. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement, Rear Facing Camera: passo 1, immagine 1 di 1
    • Before removing the camera, make sure the device is powered off
    • Use a plastic opening tool to pry open the back cover of the tablet..
  2. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: passo 2, immagine 1 di 1
    • Locate the cable that is connecting the camera to the tablet
  3. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: passo 3, immagine 1 di 1
    • Disconnect the cable that is connecting the camera to the tablet
  4. Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: passo 4, immagine 1 di 2 Lenovo Tab 2 A10-70 Rear Facing Camera  Replacement: passo 4, immagine 2 di 2
    • Simply remove the camera from the tablet by lifting it up
    • Repeat Steps in reverse order with a new camera for reassembly
Conclusione
USF Tampa, Team 12-6, Eyestone Spring 2016 Membro di USF Tampa, Team 12-6, Eyestone Spring 2016
USFT-EYESTONE-S16S12G6
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 12
Tutti i Tempi: 887
