Salta al contenuto principale
Lenovo Tab 2 A10-70 Power Button Replacement
Cosa ti serve
  1. Lenovo Tab 2 A10-70 Power Button Replacement, Power Button: passo 1, immagine 1 di 2 Lenovo Tab 2 A10-70 Power Button Replacement, Power Button: passo 1, immagine 2 di 2
    • Use a plastic opening tool to pry open the back cover of the tablet.
  2. Lenovo Tab 2 A10-70 Power Button Replacement: passo 2, immagine 1 di 1
    • The power button strip is only held in place by a small piece of double-sided tape.
    • Gently use the precision tweezers to separate the power button strip from the interior frame of the tablet.
  3. Lenovo Tab 2 A10-70 Power Button Replacement: passo 3, immagine 1 di 1
    • Be careful with the soldering iron to avoid injury.
    • Remove the power button from the motherboard.
    • Use the soldering iron to heat up the connections. Gently pull away from the motherboard after connections are detached.
Conclusione
Altre 3 persone hanno completato questa guida.
USF Tampa, Team 12-6, Eyestone Spring 2016 Membro di USF Tampa, Team 12-6, Eyestone Spring 2016
USFT-EYESTONE-S16S12G6
4 Membri
10 Guide realizzate
Un commento
Thank you for making this helpfull instrutions.
Where i can get the Buttons?
Simon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 35
Tutti i Tempi: 6,789
