Introduzione
This guide shows how to take apart the Lenovo Slim DVD Burner DB65 to replace the disc tray locking mechanism.
  1. Flip the unit over so that way the bottom is facing you. Remove the two black 7.6mm Phillips #0 screws from the bottom cover.
    • Flip the unit over so that way the bottom is facing you.
    • Remove the two black 7.6mm Phillips #0 screws from the bottom cover.
  2. Use the iFixit Opening Tool to gently pry the unit apart to gain access to the interior. If the top seems stuck, run the iFixit Opening Tool along the edge while simultaneously pulling up on the top with your fingers. Continue to apply pressure until it opens completely.
    • Use the iFixit Opening Tool to gently pry the unit apart to gain access to the interior.
    • If the top seems stuck, run the iFixit Opening Tool along the edge while simultaneously pulling up on the top with your fingers. Continue to apply pressure until it opens completely.
  3. Open the device tray by inserting a paper clip into the eject hole. Open the device tray by inserting a paper clip into the eject hole.
    • Open the device tray by inserting a paper clip into the eject hole.
  4. Spedizione gratuita per tutti gli ordini superiori a 100 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
  5. Turn the unit over and remove the two silver 3mm Phillips #0 screws from the aluminum cover. Turn the unit over and remove the two silver 3mm Phillips #0 screws from the aluminum cover.
    • Turn the unit over and remove the two silver 3mm Phillips #0 screws from the aluminum cover.
  6. Lift the silver coverup to expose the internal components.
    • Lift the silver coverup to expose the internal components.
    • If the cover seems stuck gently pull up on one edge. The cover should remove completely after one side is free.
  7. Remove the single 3mm Phillips #0 screw. Remove the single 3mm Phillips #0 screw.
    • Remove the single 3mm Phillips #0 screw.
  8. Lift and remove the silver tray locking mechanism by detaching the spring which is hooked on the white plastic internal component. Be careful when removing this mechanism—the spring is delicate.
    • Lift and remove the silver tray locking mechanism by detaching the spring which is hooked on the white plastic internal component.
    • Be careful when removing this mechanism—the spring is delicate.
Conclusione
Matthew Green
Membro da: 05/07/2018
337 Reputazione
2 Guide realizzate
IUPUI, Team S2-G1, Harley Summer 2018 Membro di IUPUI, Team S2-G1, Harley Summer 2018
IUPUI-HARLEY-SU18S2G1
3 Membri
2 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 25
Tutti i Tempi: 167
