Salta al contenuto principale
Lenovo S20-30 Keyboard Replacement
Cosa ti serve
  1. Lenovo S20-30 Keyboard Replacement, Battery: passo 1, immagine 1 di 1
    • Flip the Lenovo S20-30 over so that the bottom panel is facing upward.
  2. Lenovo S20-30 Keyboard Replacement: passo 2, immagine 1 di 1
    • Slide the manual battery latch to the unlock position, so that the red is showing.
  3. Lenovo S20-30 Keyboard Replacement: passo 3, immagine 1 di 2 Lenovo S20-30 Keyboard Replacement: passo 3, immagine 2 di 2
    • Slide and hold the spring-loaded battery latch on the other side (right) while sliding the battery out of the computer.
    • Grab new Lenovo S20-30 battery for replacement.
  4. Lenovo S20-30 Keyboard Replacement, Keyboard: passo 4, immagine 1 di 3 Lenovo S20-30 Keyboard Replacement, Keyboard: passo 4, immagine 2 di 3 Lenovo S20-30 Keyboard Replacement, Keyboard: passo 4, immagine 3 di 3
    • Remove the two front rubber feet using a long metal spudger.
    • Use your Phillips #0 screwdriver to remove the two M2.5 x 5mm flat-head screws located underneath the pads.
  5. Lenovo S20-30 Keyboard Replacement: passo 5, immagine 1 di 1
    • Use the Phillips #0 screwdriver to remove the nine M2 x 4mm flat head screws located on the outer edges on the back of the laptop.
    • Make sure to keep these screws separated from future screws that will be disassembled throughout this process.
  6. Lenovo S20-30 Keyboard Replacement: passo 6, immagine 1 di 2 Lenovo S20-30 Keyboard Replacement: passo 6, immagine 2 di 2
    • Use the long metal spudger to pry open the bottom half of the laptop.
    • Gently lift the cover off to reveal the motherboard.
  7. Lenovo S20-30 Keyboard Replacement: passo 7, immagine 1 di 2 Lenovo S20-30 Keyboard Replacement: passo 7, immagine 2 di 2
    • Remove the four M2 x 3mm flat-head screw using a Phillips #000 screwdriver.
  8. Lenovo S20-30 Keyboard Replacement: passo 8, immagine 1 di 2 Lenovo S20-30 Keyboard Replacement: passo 8, immagine 2 di 2
    • Flip over laptop and open the lid to have access to the keyboard.
    • Use a plastic opening tool to pry apart the keyboard.
  9. Lenovo S20-30 Keyboard Replacement: passo 9, immagine 1 di 3 Lenovo S20-30 Keyboard Replacement: passo 9, immagine 2 di 3 Lenovo S20-30 Keyboard Replacement: passo 9, immagine 3 di 3
    • A connector is attached to the keyboard.
    • Remove it by gently pulling it outward.
  10. Lenovo S20-30 Keyboard Replacement: passo 10, immagine 1 di 1
    • Grab replacement keyboard to insert back into place.
Conclusione
Altre 3 persone hanno completato questa guida.
Un commento
where can i find a replacement keyboard/ or what model # do i need?
ed paz - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,230
