Salta al contenuto principale
Lenovo N23 Yoga Keyboard Replacement
Cosa ti serve
  1. Lenovo N23 Yoga Keyboard Replacement, Keyboard: passo 1, immagine 1 di 3 Lenovo N23 Yoga Keyboard Replacement, Keyboard: passo 1, immagine 2 di 3 Lenovo N23 Yoga Keyboard Replacement, Keyboard: passo 1, immagine 3 di 3
    • Flip the computer over.
    • Remove the 9 screws surrounding the edges of the computer.
    • Remove the single screw near the center of the computer.
  2. Lenovo N23 Yoga Keyboard Replacement: passo 2, immagine 1 di 1
    • Use a smaller plastic panel popping tool to begin (if you have one). You may increase to a larger size as you go (if you have one)
    • Slowly work your way around the edges of the computer.
    • Closer to the screen the clips will be sturdier, use a little more force but still be cautious.
  3. Lenovo N23 Yoga Keyboard Replacement: passo 3, immagine 1 di 1
    • On the main board, lift up on the black tabs of the connectors that are connected to the ribbons.
    • Remove the ribbon connectors gently from the main board.
  4. Lenovo N23 Yoga Keyboard Replacement: passo 4, immagine 1 di 1
    • The keyboard should be free and disconnected from the rest of the computer.
Conclusione
Altre 2 persone hanno completato questa guida.
Drew Canada
Membro da: 04/03/18
1.370 Reputazione
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 9
Tutti i Tempi: 1,537
