Salta al contenuto principale
Lenovo N23 Keyboard Replacement
Cosa ti serve
  1. Lenovo N23 Keyboard Replacement, Removing Back Cover: passo 1, immagine 1 di 1
    • Power Down the Chromebook before starting the repair
    • Opening the Chromebook voids the manufacturer warranty
    • Flip the Chromebook so that the bottom is facing upwards
    • Use a Phillips #1 screwdriver to remove the eight 6.6 mm screws in the bottom.
  2. Lenovo N23 Keyboard Replacement, Opening up Keyboard: passo 2, immagine 1 di 1
    • Flip the Chromebook over and open the screen
    • Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook
    • Be careful of the tabs on the inside of the keyboard and Chromebook, be cautious or these could break, too
    • Run the plastic tool along the seam, popping up the keyboard until you can freely lift up the keyboard
    • It is normal for the tabs to make a loud popping sounds when released. The corner tabs are harder to remove and will make a louder click when released.
  3. Lenovo N23 Keyboard Replacement, Releasing Keyboard from Motherboard: passo 3, immagine 1 di 1
    • Once the keyboard is released, grab the top two corners closest to the screen and slowly lift the keyboard up
    • Do not lift the keyboard too quickly, or you might break the two cables that connect the keyboard to the motherboard
    • The motherboard is now exposed DO NOT use any tools with metal, you may short circuit and fry the motherboard
    • Disconnect the cables by lifting up on the retaining tabs on the blank ZIF connectors
    • Slowly pull the cables up and out of the connectors
  4. Lenovo N23 Keyboard Replacement: passo 4, immagine 1 di 1
    • Lift the keyboard up and off of the back retainers, completely removing the keyboard from the Chromebook
    • To reassemble your device, follow these instructions in reverse order.
Conclusione
Altre 2 persone hanno completato questa guida.
Robin Mores
Membro da: 05/06/19
166 Reputazione
1 Guida realizzata
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 23
Tutti i Tempi: 1,259
