Salta al contenuto principale
Lenovo N22 Chromebook Speakers Replacement
Cosa ti serve
  1. Lenovo N22 Chromebook Speakers Replacement, Keyboard: passo 1, immagine 1 di 3 Lenovo N22 Chromebook Speakers Replacement, Keyboard: passo 1, immagine 2 di 3 Lenovo N22 Chromebook Speakers Replacement, Keyboard: passo 1, immagine 3 di 3
    • Power down the Chromebook before starting the repair.
    • Opening the Chromebook voids the manufacturer warranty.
    • Flip the Chromebook so that the bottom is facing up.
    • Use a Phillips #1 screwdriver to remove the six 6.6 mm screws on the bottom.
    • Use a spudger to remove each of the 4 rubber feet.
    • Use a Phillips #1 screwdriver to remove the four additional screws under the rubber feet.
  2. Lenovo N22 Chromebook Speakers Replacement: passo 2, immagine 1 di 3 Lenovo N22 Chromebook Speakers Replacement: passo 2, immagine 2 di 3 Lenovo N22 Chromebook Speakers Replacement: passo 2, immagine 3 di 3
    • Flip the Chromebook back over and open the screen.
    • Wedge the plastic opening tool between the keyboard and the bottom of the Chromebook.
    • Run the plastic opening tool along the seam between the keyboard and the bottom of the Chromebook until the keyboard moves freely. Several tabs will pop out.
    • It is normal for the tabs to make a loud click when released. The corner tabs will be harder to release than the others and will make a louder click.
  3. Lenovo N22 Chromebook Speakers Replacement: passo 3, immagine 1 di 2 Lenovo N22 Chromebook Speakers Replacement: passo 3, immagine 2 di 2
    • Once the keyboard is released, grab the two top corners closest to the screen and slowly lift the keyboard up.
    • Do not lift the keyboard quickly or you might break the two cables that connect the keyboard to the motherboard.
    • Disconnect the cables by lifting up the retaining flaps on the black ZIF connectors.
    • Slowly pull the cables up and out of the connectors.
  4. Lenovo N22 Chromebook Speakers Replacement: passo 4, immagine 1 di 1
    • Lift the keyboard up and off the back panel, exposing the motherboard and battery.
  5. Lenovo N22 Chromebook Speakers Replacement, Battery: passo 5, immagine 1 di 2 Lenovo N22 Chromebook Speakers Replacement, Battery: passo 5, immagine 2 di 2
    • Separate the battery cable from the motherboard by wedging the edge of a plastic opening tool between the black cable connector and the silver socket on the motherboard.
    • Pull the battery cable straight towards you, away from the silver socket.
  6. Lenovo N22 Chromebook Speakers Replacement: passo 6, immagine 1 di 2 Lenovo N22 Chromebook Speakers Replacement: passo 6, immagine 2 di 2
    • Use a Philips #1 screwdriver to remove the three 4.3 mm screws securing the battery.
  7. Lenovo N22 Chromebook Speakers Replacement: passo 7, immagine 1 di 2 Lenovo N22 Chromebook Speakers Replacement: passo 7, immagine 2 di 2
    • Lift up on the tabs that were held down by the screws to remove the battery.
  8. Lenovo N22 Chromebook Speakers Replacement, Speakers: passo 8, immagine 1 di 1
    • Use the edge of the opening tool to separate the speaker cable connector from the black socket on the motherboard.
    • Pull the cables towards you and away from the socket.
  9. Lenovo N22 Chromebook Speakers Replacement: passo 9, immagine 1 di 2 Lenovo N22 Chromebook Speakers Replacement: passo 9, immagine 2 di 2
    • Use the pointed end of the spudger to pop the speaker up and off of the two posts.
  10. Lenovo N22 Chromebook Speakers Replacement: passo 10, immagine 1 di 2 Lenovo N22 Chromebook Speakers Replacement: passo 10, immagine 2 di 2
    • Slide the wire that connects the two separate speakers out from under the guide tabs.
  11. Lenovo N22 Chromebook Speakers Replacement: passo 11, immagine 1 di 2 Lenovo N22 Chromebook Speakers Replacement: passo 11, immagine 2 di 2
    • Use the flat end of the spudger to pop the speaker up and off of the two posts.
Conclusione
Cal Poly, Team S21-G1, Livingston Spring 2017 Membro di Cal Poly, Team S21-G1, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G1
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 18
Tutti i Tempi: 774
