Salta al contenuto principale
Lenovo N20p Chromebook Keyboard Replacement
Cosa ti serve
  1. Lenovo N20p Chromebook Keyboard Replacement, Keyboard: passo 1, immagine 1 di 2 Lenovo N20p Chromebook Keyboard Replacement, Keyboard: passo 1, immagine 2 di 2
    • Power down the Chromebook before starting any repair.
    • Remove the two 3.5 mm Phillips #0 screws using a screwdriver.
    • It is only necessary to remove these two screws to complete this step.
  2. Lenovo N20p Chromebook Keyboard Replacement: passo 2, immagine 1 di 2 Lenovo N20p Chromebook Keyboard Replacement: passo 2, immagine 2 di 2
    • Use the hook of the metal spudger to carefully lift up the keyboard.
    • Lift the keyboard carefully. If you lift too quickly, it might break the two cables that connect the keyboard to the motherboard.
  3. Lenovo N20p Chromebook Keyboard Replacement: passo 3, immagine 1 di 3 Lenovo N20p Chromebook Keyboard Replacement: passo 3, immagine 2 di 3 Lenovo N20p Chromebook Keyboard Replacement: passo 3, immagine 3 di 3
    • Carefully, disconnect the keyboard cable from the motherboard carefully by pulling on the blue tab of the cable.
    • You will now be able to replace the keyboard.
Conclusione
Shihao Cao
Membro da: 07/12/18
497 Reputazione
4 Guide realizzate
UW Tacoma, Team S1-G2, Cardinal Summer 2018 Membro di UW Tacoma, Team S1-G2, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G2
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 287
