Salta al contenuto principale
Lenovo N20p Chromebook I/O Board Replacement
Cosa ti serve
  1. Lenovo N20p Chromebook  I/O Board Replacement, Keyboard: passo 1, immagine 1 di 2 Lenovo N20p Chromebook  I/O Board Replacement, Keyboard: passo 1, immagine 2 di 2
    • Power down the Chromebook before starting any repair.
    • Remove the two 3.5 mm Phillips #0 screws using a screwdriver.
    • It is only necessary to remove these two screws to complete this step.
  2. Lenovo N20p Chromebook  I/O Board Replacement: passo 2, immagine 1 di 2 Lenovo N20p Chromebook  I/O Board Replacement: passo 2, immagine 2 di 2
    • Use the hook of the metal spudger to carefully lift up the keyboard.
    • Lift the keyboard carefully. If you lift too quickly, it might break the two cables that connect the keyboard to the motherboard.
  3. Lenovo N20p Chromebook  I/O Board Replacement: passo 3, immagine 1 di 3 Lenovo N20p Chromebook  I/O Board Replacement: passo 3, immagine 2 di 3 Lenovo N20p Chromebook  I/O Board Replacement: passo 3, immagine 3 di 3
    • Carefully, disconnect the keyboard cable from the motherboard carefully by pulling on the blue tab of the cable.
    • You will now be able to replace the keyboard.
  4. Lenovo N20p Chromebook  I/O Board Replacement, Battery: passo 4, immagine 1 di 3 Lenovo N20p Chromebook  I/O Board Replacement, Battery: passo 4, immagine 2 di 3 Lenovo N20p Chromebook  I/O Board Replacement, Battery: passo 4, immagine 3 di 3
    • Remove the two rubber feet of the back of the Chromebook using a metal spudger.
    • Remove six bottom 3.5 mm Phillips #0 screws and two top 5 mm Phillips #1 screws.
  5. Lenovo N20p Chromebook  I/O Board Replacement: passo 5, immagine 1 di 1
    • Remove all nine 3.5 mm Phillips #00 screws using a screwdriver.
  6. Lenovo N20p Chromebook  I/O Board Replacement: passo 6, immagine 1 di 2 Lenovo N20p Chromebook  I/O Board Replacement: passo 6, immagine 2 di 2
    • Disconnect the battery cable from the motherboard.
    • Disconnect the touch-pad cable from the motherboard.
  7. Lenovo N20p Chromebook  I/O Board Replacement: passo 7, immagine 1 di 2 Lenovo N20p Chromebook  I/O Board Replacement: passo 7, immagine 2 di 2
    • Use the metal spudger along the seam between the keyboard and the bottom of the Chromebook to lift up and remove the palm rest assembly.
    • It is normal for it to click loudly when it is released. Corner tags will be harder to release than other tags and will make a loud sound.
  8. Lenovo N20p Chromebook  I/O Board Replacement: passo 8, immagine 1 di 3 Lenovo N20p Chromebook  I/O Board Replacement: passo 8, immagine 2 di 3 Lenovo N20p Chromebook  I/O Board Replacement: passo 8, immagine 3 di 3
    • Disconnect the USB cable from the motherboard by pulling the blue tab out of the cable.
    • Remove all five 3.0 mm Phillips #00 screws which connect the battery and motherboard.
  9. Lenovo N20p Chromebook  I/O Board Replacement: passo 9, immagine 1 di 2 Lenovo N20p Chromebook  I/O Board Replacement: passo 9, immagine 2 di 2
    • Remove the battery.
    • It is helpful to lift and hold the battery as shown.
  10. Lenovo N20p Chromebook  I/O Board Replacement, I/O Board: passo 10, immagine 1 di 1
    • Once the battery has been removed, you need make sure that you have removed the I/O cable that is attached to the I/O Board.
    • Using the flat end of the Spudger tool, carefully lift the I/O Board.
  11. Lenovo N20p Chromebook  I/O Board Replacement: passo 11, immagine 1 di 1
    • You will now be able to replace the I/O Board.
Conclusione
Shihao Cao
Membro da: 07/12/18
497 Reputazione
4 Guide realizzate
UW Tacoma, Team S1-G2, Cardinal Summer 2018 Membro di UW Tacoma, Team S1-G2, Cardinal Summer 2018
UWT-CARDINAL-SU18S1G2
3 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 10
Tutti i Tempi: 252
