Introduzione
here is a guide to help you locate the I/O Board for inspection, repairs, or replacement. The tools you will need are the Phillips #0 Screwdriver, Metal Spudger, and the Spudger.
Cosa ti serve
Remove the two rubber feet of the back of the Chromebook using a metal spudger.
Remove six bottom 3.5 mm Phillips #0 screws and two top 5 mm Phillips #1 screws.
Once the battery has been removed, you need make sure that you have removed the I/O cable that is attached to the I/O Board.
Using the flat end of the Spudger tool, carefully lift the I/O Board.
