Salta al contenuto principale
Lenovo Miix 2 Battery Replacement
Cosa ti serve
  1. Lenovo Miix 2 Battery Replacement, Battery: passo 1, immagine 1 di 2 Lenovo Miix 2 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Remove the back cover of the tablet by inserting a nylon or metal spudger in the small hole between the screen and rear cover near the volume button. Slide the tool along the edge of the tablet to release the internal clasps.
    • You should have to apply a good amount of force, but pry carefully in order to avoid damaging the clasps or the internals.
  2. Lenovo Miix 2 Battery Replacement: passo 2, immagine 1 di 2 Lenovo Miix 2 Battery Replacement: passo 2, immagine 2 di 2
    • Unscrew the six 3mm screws surrounding the battery dock using a Phillips #0 screwdriver.
  3. Lenovo Miix 2 Battery Replacement: passo 3, immagine 1 di 2 Lenovo Miix 2 Battery Replacement: passo 3, immagine 2 di 2
    • Using a plastic spudger, slowly push each side of the battery connector (back and forward a couple of times) out of its socket on the motherboard.
  4. Lenovo Miix 2 Battery Replacement: passo 4, immagine 1 di 2 Lenovo Miix 2 Battery Replacement: passo 4, immagine 2 di 2
    • Remove the battery by prying up with your fingers or a plastic opening tool.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 5-8, Maness Spring 2015 Membro di Cal Poly, Team 5-8, Maness Spring 2015
CPSU-MANESS-S15S5G8
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 31
Tutti i Tempi: 8,921
