Salta al contenuto principale
Lenovo Legion Y530-15ICH Wifi Card Replacement
Cosa ti serve
  1. Lenovo Legion Y530-15ICH Wifi Card Replacement, Remove the back plate: passo 1, immagine 1 di 1
    • Remove the 5 long and 6 short Phillips head screws on the back of the computer (I am missing one). They are located around the perimeter of the bottom as well as one in the center of the fan grille. Take off the back cover.
  2. Lenovo Legion Y530-15ICH Wifi Card Replacement, Locate the Wifi Card: passo 2, immagine 1 di 1
    • The wifi card is directly above the battery and under the right fan.
    • Remove the connections to the antenna for the card. On my Realtek 8822BE model they are white and black. Yours may be a different color but the process is identical
  3. Lenovo Legion Y530-15ICH Wifi Card Replacement, Unscrew the Wifi Card: passo 4, immagine 1 di 1
    • Use the same Phillips driver you used to open the case and unscrew the card. Be careful.
  4. Lenovo Legion Y530-15ICH Wifi Card Replacement, Carefully remove the card: passo 5, immagine 1 di 1
    • Pull gently and the card will remove. To put in a new card just repeat these steps in reverse.
Conclusione
To reassemble your device, follow these instructions in reverse order. Be sure to keep your hands dry and be careful with electronics.
P_enta
Membro da: 12/12/20
368 Reputazione
1 Guida realizzata
4 Commenti
which alternative do you recommend?
Vineet Gandham - Replica
Is there a list of compatible WiFi cards? I've read that the Intel AX210/211 may also be compatible, but I haven't been able to get any confirmation.
Ken walia - Replica
Mine lenovo Legion Y530-15ICH not boots with new AX211NGW
Roland Eihe - Replica
Is there any restriction in BIOS for Wifi Card Replacement?
for Lenovo Legion Y530-15ICH Laptop, serial: PF1JD34B
Gev Artanyan - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 18
Ultimi 30 Giorni: 87
Tutti i Tempi: 5,778
