Salta al contenuto principale
Lenovo Legion Y530-15ICH USB Port Replacement
Cosa ti serve
  1. Lenovo Legion Y530-15ICH USB Port Replacement, Back Cover: passo 1, immagine 1 di 1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7 mm screws
    • Six 4 mm screws
  2. Lenovo Legion Y530-15ICH USB Port Replacement: passo 2, immagine 1 di 2 Lenovo Legion Y530-15ICH USB Port Replacement: passo 2, immagine 2 di 2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH USB Port Replacement, USB Port: passo 3, immagine 1 di 2 Lenovo Legion Y530-15ICH USB Port Replacement, USB Port: passo 3, immagine 2 di 2
    • Remove the ribbon cable connecting the USB port to the motherboard, located adjacent to the fan unit.
    • Using a JIS #1 screwdriver, remove the two screws securing the USB port to the module.
  4. Lenovo Legion Y530-15ICH USB Port Replacement: passo 4, immagine 1 di 1
    • Gently disconnect the single ribbon cable with your fingers.
    • Remove the USB port from the device.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,004
