Salta al contenuto principale
Lenovo Legion Y530-15ICH Solid State Drive Replacement
Cosa ti serve
  1. Lenovo Legion Y530-15ICH Solid State Drive Replacement, Back Cover: passo 1, immagine 1 di 1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7mm screws
    • Two 6mm screws
    • Four 4mm screws
  2. Lenovo Legion Y530-15ICH Solid State Drive Replacement: passo 2, immagine 1 di 2 Lenovo Legion Y530-15ICH Solid State Drive Replacement: passo 2, immagine 2 di 2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Solid State Drive Replacement, Solid State Drive: passo 3, immagine 1 di 2 Lenovo Legion Y530-15ICH Solid State Drive Replacement, Solid State Drive: passo 3, immagine 2 di 2
    • Do not remove the thermal pad.
    • Remove one 4mm screw circled in orange in the second picture with a JIS #1 screwdriver.
  4. Lenovo Legion Y530-15ICH Solid State Drive Replacement: passo 4, immagine 1 di 2 Lenovo Legion Y530-15ICH Solid State Drive Replacement: passo 4, immagine 2 di 2
    • Carefully remove the SSD from its connector.
Conclusione
Insert your new SSD into the connector. To reassemble your device, follow these instructions in reverse order.
Cal Poly, Team S7-G1, Regan Winter 2020 Membro di Cal Poly, Team S7-G1, Regan Winter 2020
CPSU-REGAN-W20S7G1
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 32
Tutti i Tempi: 5,534
