Salta al contenuto principale
Lenovo Legion Y530-15ICH Motherboard Replacement
Cosa ti serve
  1. Lenovo Legion Y530-15ICH Motherboard Replacement, Back Cover: passo 1, immagine 1 di 1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7 mm screws
    • Six 4 mm screws
  2. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 2, immagine 1 di 2 Lenovo Legion Y530-15ICH Motherboard Replacement: passo 2, immagine 2 di 2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Motherboard Replacement, Battery: passo 3, immagine 1 di 1
    • Use a Phillips screwdriver to remove the five 4 mm screws holding the battery in place.
  4. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 4, immagine 1 di 2 Lenovo Legion Y530-15ICH Motherboard Replacement: passo 4, immagine 2 di 2
    • Disconnect the battery cable from its motherboard socket by gently pulling it towards the battery.
    • Pull parallel to the battery, not straight up.
    • Now you can safely remove the battery.
  5. Lenovo Legion Y530-15ICH Motherboard Replacement, Fan: passo 5, immagine 1 di 2 Lenovo Legion Y530-15ICH Motherboard Replacement, Fan: passo 5, immagine 2 di 2
    • Use a JIS #1 screwdriver to loosen the five spring screws located at the middle of the fan piece.
    • Remove the plastic covering after the screws have been loosened.
    • Spring screws will stay attached to the cover.
  6. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 6, immagine 1 di 1
    • Use a JIS #1 screwdriver to remove four 4mm screws securing the fans to the device.
  7. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 7, immagine 1 di 1
    • Unplug the wires connecting the two fans to the motherboard.
    • When doing this, tug carefully from side to side.
  8. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 8, immagine 1 di 2 Lenovo Legion Y530-15ICH Motherboard Replacement: passo 8, immagine 2 di 2
    • Lift the fans out of their positions and remove them from the device.
  9. Lenovo Legion Y530-15ICH Motherboard Replacement, Solid State Drive: passo 9, immagine 1 di 2 Lenovo Legion Y530-15ICH Motherboard Replacement, Solid State Drive: passo 9, immagine 2 di 2
    • Do not remove the thermal pad.
    • Remove one 4mm screw circled in orange in the second picture with a JIS #1 screwdriver.
  10. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 10, immagine 1 di 2 Lenovo Legion Y530-15ICH Motherboard Replacement: passo 10, immagine 2 di 2
    • Carefully remove the SSD from its connector.
  11. Lenovo Legion Y530-15ICH Motherboard Replacement, Motherboard: passo 11, immagine 1 di 2 Lenovo Legion Y530-15ICH Motherboard Replacement, Motherboard: passo 11, immagine 2 di 2
    • Start by disconnecting the ribbon cable that is near the audio driver. It is recommended to use the iFixit Opening Pick to remove the ribbon cable.
  12. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 12, immagine 1 di 2 Lenovo Legion Y530-15ICH Motherboard Replacement: passo 12, immagine 2 di 2
    • Remove three 4mm screws using a JIS #1 screwdriver.
    • Remove the black cover the screws were holding down.
  13. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 13, immagine 1 di 2 Lenovo Legion Y530-15ICH Motherboard Replacement: passo 13, immagine 2 di 2
    • Remove the 4mm screw on top of the audio driver using a JIS #1 screwdriver.
    • Pull the audio cables gently off the audio driver.
    • Remove the audio driver from the motherboard.
  14. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 14, immagine 1 di 1
    • Remove twelve 4mm screws circled in red using a JIS #1 screwdriver.
    • Peel off the Lenovo sticker and remove one 4mm screw with a JIS #1 screwdriver.
  15. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 15, immagine 1 di 1
    • Remove two ribbon cables in the circled areas. Gently pull them out of their ports.
  16. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 16, immagine 1 di 1
    • Remove the final ribbon cable by gently pulling it from its socket.
    • The motherboard is now completely disconnected from the laptop.
  17. Lenovo Legion Y530-15ICH Motherboard Replacement: passo 17, immagine 1 di 2 Lenovo Legion Y530-15ICH Motherboard Replacement: passo 17, immagine 2 di 2
    • Gently lift the motherboard out of the housing.
Conclusione
Altre 4 persone hanno completato questa guida.
Cal Poly, Team S7-G1, Regan Winter 2020 Membro di Cal Poly, Team S7-G1, Regan Winter 2020
CPSU-REGAN-W20S7G1
4 Membri
12 Guide realizzate
3 Commenti
Kaylie Klausing
I hope you burn in !&&*
Safwat Ali - Replica
You fckking piece of $@$*.
DON'T FOLLOW THIS.
FCKKKK YOUUUUU
What the hell is wrong with this guy?
Safwat Ali is a real jerk - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 21
Ultimi 30 Giorni: 120
Tutti i Tempi: 8,303
