Salta al contenuto principale
Lenovo Legion Y530-15ICH Fan Replacement
Cosa ti serve
  1. Lenovo Legion Y530-15ICH Fan Replacement, Back Cover: passo 1, immagine 1 di 1
    • Ensure the device is powered off.
    • Use a PZ00 screwdriver bit to remove the eleven screws securing the back cover.
    • Five 7mm screws
    • Two 6mm screws
    • Four 4mm screws
  2. Lenovo Legion Y530-15ICH Fan Replacement: passo 2, immagine 1 di 2 Lenovo Legion Y530-15ICH Fan Replacement: passo 2, immagine 2 di 2
    • Carefully pry the back cover off the computer using an opening pick.
    • Start at the corner of the laptop and work your way around the side. Gently pull up on the cover until it detaches.
  3. Lenovo Legion Y530-15ICH Fan Replacement, Fan: passo 3, immagine 1 di 2 Lenovo Legion Y530-15ICH Fan Replacement, Fan: passo 3, immagine 2 di 2
    • Use a JIS #1 screwdriver to loosen the five spring screws located at the middle of the fan piece.
    • Remove the plastic covering after the screws have been loosened.
    • Spring screws will stay attached to the cover.
    There were 6 holding the heat sink on when I did it.
    Bryce Christensen - Replica
  4. Lenovo Legion Y530-15ICH Fan Replacement: passo 4, immagine 1 di 1
    • Use a JIS #1 screwdriver to remove four 4mm screws securing the fans to the device.
  5. Lenovo Legion Y530-15ICH Fan Replacement: passo 5, immagine 1 di 1
    • Unplug the wires connecting the two fans to the motherboard.
    • When doing this, tug carefully from side to side.
  6. Lenovo Legion Y530-15ICH Fan Replacement: passo 6, immagine 1 di 2 Lenovo Legion Y530-15ICH Fan Replacement: passo 6, immagine 2 di 2
    • Lift the fans out of their positions and remove them from the device.
    Don't forget to pick up thermal paste so you get a good contact between the CPU and GPU and the heat sinks!
Conclusione
Altre 6 persone hanno completato questa guida.
Cal Poly, Team S7-G1, Regan Winter 2020 Membro di Cal Poly, Team S7-G1, Regan Winter 2020
CPSU-REGAN-W20S7G1
4 Membri
12 Guide realizzate
4Commenti sulla guida
Thank you! Very clear and well photographed :)
Daniel Perez - Replica
Any recommended stores for the replacement fans?
Ivan Ramljak - Replica
Worked like a charm, thank you!!
Skyler Boyle - Replica
where can i get a good replacement please
peters pelumi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 34
Ultimi 30 Giorni: 137
Tutti i Tempi: 14,301
