Introduzione
This guide explains how to replace the hard drive in your Lenovo Legion. You may be replacing a fried hard drive or you may be upgrading memory. A hard drive can also be removed in order to put a solid state drive in place.
Cosa ti serve
Remove the thirteen 6.5 mm screws from the bottom of the laptop using a Phillips #00 screwdriver.
Altre 8 persone hanno completato questa guida.
Un commento
Hi,
does anyone know if replacing the 1TB hard disk with a 1TB SSD is possible? (I’m thinking in terms of cloning the whole disk: can I go for a 1TB SSD or do I need a bigger one? Do hidden partitions for restoring the system / this kind of stuff get copied correctly? Most tutorials online just copy the Windows partition: wouldn’t want to find out I can’t reset the system if needed.)
