Salta al contenuto principale
Lenovo Legion Y520-15IKBN Base Panel Replacement
Cosa ti serve
  1. Lenovo Legion Y520-15IKBN Base Panel Replacement, Base Panel: passo 1, immagine 1 di 2 Lenovo Legion Y520-15IKBN Base Panel Replacement, Base Panel: passo 1, immagine 2 di 2
    • Shut down and unplug your device before proceeding.
    • Remove the thirteen 6.5 mm screws from the base plate using a Phillips #00 screwdriver.
  2. Lenovo Legion Y520-15IKBN Base Panel Replacement: passo 2, immagine 1 di 1
    • Flip the laptop on its side and wedge a spudger between the base panel and chassis, then pry around the perimeter until the base panel releases.
    • To get a better grip you may want to open the laptop slightly.
    • Lift the bottom panel off of the chassis.
    • During reassembly, make sure that the bottom panel clicks back into place on all four sides of the laptop.
Conclusione
Connor
Membro da: 03/29/22
12.543 Reputazione
64 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.645 Guide realizzate
1Commento della guida
I was wondering, do you know the gauge of the the 13 case screws? I'm trying to replace some I've lost for the case as well as the interior screws around the fan and heatsink.
Samuel Anklin - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 52
Tutti i Tempi: 1,240
