Salta al contenuto principale
Lenovo Ideatab A1107 Battery Replacement
Cosa ti serve
  1. Lenovo Ideatab A1107 Battery Replacement, Back Cover: passo 1, immagine 1 di 2 Lenovo Ideatab A1107 Battery Replacement, Back Cover: passo 1, immagine 2 di 2
    • Insert a plastic opener in-between the black back panel and the silver body of the tablet.
    • Use the plastic opener to pry the back panel off by moving the plastic opener around the outside edge of the device.
  2. Lenovo Ideatab A1107 Battery Replacement: passo 2, immagine 1 di 2 Lenovo Ideatab A1107 Battery Replacement: passo 2, immagine 2 di 2
    • Use a Phillips #000 screwdriver to remove the seventeen 4mm screws.
  3. Lenovo Ideatab A1107 Battery Replacement: passo 3, immagine 1 di 1
    • Lift up and remove the interior casing to expose the inner components.
    • Do not be alarmed if the volume button and lock button fall off when removing the interior casing.
  4. Lenovo Ideatab A1107 Battery Replacement, Battery: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to remove the tape covering the battery's wiring.
  5. Lenovo Ideatab A1107 Battery Replacement: passo 5, immagine 1 di 2 Lenovo Ideatab A1107 Battery Replacement: passo 5, immagine 2 di 2
    • Do not puncture the lithium-ion battery. Ruptured batteries can catch fire or explode.
    • Do not use metal tools to remove the battery wire. They present the risk of electrocution.
    • Use a plastic spudger tool to push the battery's wire harness and disconnect it from the device.
  6. Lenovo Ideatab A1107 Battery Replacement: passo 6, immagine 1 di 1
    • Wedge a plastic opening tool in between the battery and the internal components of the device.
    • Use the plastic opener tool to remove the battery from its casing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 10
Tutti i Tempi: 422
