Introduzione
The battery can possibly die quickly although the laptop can turn on when the charging cord is connected. This issue is the result of needing a battery replacement. This guide will show how to remove and replace your battery.
Cosa ti serve
Begin by turning your closed laptop so that you are looking at the bottom panel.
Locate the battery in the bottom right corner.
Using a Phillips #000, remove the 6 screws (3.5mm) on the border of the battery and the 7th screw (6.5mm) that is in the center of the battery.
Locate the cable connecting to the battery. It is located at the top-center of the battery.
Use a pair of tweezers and place it so that the tweezer is around the cables. Gently pull the cables towards the battery to disconnect the cable.
Altre 2 persone hanno completato questa guida.
