Salta al contenuto principale
Lenovo Ideapad Y700 15-ISK Hard Drive Replacement
Cosa ti serve
  1. Lenovo Ideapad Y700 15-ISK Hard Drive Replacement, Preparing the laptop for disassembly.: passo 1, immagine 1 di 2 Lenovo Ideapad Y700 15-ISK Hard Drive Replacement, Preparing the laptop for disassembly.: passo 1, immagine 2 di 2
    • Shut down the laptop.
    • Disconnect the power plug.
    • Close the laptop.
  2. Lenovo Ideapad Y700 15-ISK Hard Drive Replacement, Opening the back panel.: passo 2, immagine 1 di 3 Lenovo Ideapad Y700 15-ISK Hard Drive Replacement, Opening the back panel.: passo 2, immagine 2 di 3 Lenovo Ideapad Y700 15-ISK Hard Drive Replacement, Opening the back panel.: passo 2, immagine 3 di 3
    • Flip the laptop upside down.
    • Remove these 11 screws with a phillips screwdriver.
    • Remove the cover by putting something thin between the cover and the base and then pushing towards the cooling vents, carefully lift it.
  3. Lenovo Ideapad Y700 15-ISK Hard Drive Replacement, Removing the disk from the laptop.: passo 3, immagine 1 di 2 Lenovo Ideapad Y700 15-ISK Hard Drive Replacement, Removing the disk from the laptop.: passo 3, immagine 2 di 2
    • Remove these 4 screws with a phillips screwdriver.
    • Uclip and disconnect the ribbon cable.
    • Remove the disk from the laptop.
  4. Lenovo Ideapad Y700 15-ISK Hard Drive Replacement, Removing the bracket.: passo 4, immagine 1 di 3 Lenovo Ideapad Y700 15-ISK Hard Drive Replacement, Removing the bracket.: passo 4, immagine 2 di 3 Lenovo Ideapad Y700 15-ISK Hard Drive Replacement, Removing the bracket.: passo 4, immagine 3 di 3
    • Unplug the SATA adaptor from the disk.
    • Remove the disk from the bracket.
Conclusione
The drive is out. To install a new one, just follow the steps in the opposite order.
Altre 5 persone hanno completato questa guida.
6 Commenti
Friend, I tried to remove the cover after removing all the screws, but it seemed to be locked.
rpvale2002 - Replica
You need to carefully pry the bottom cover with something thin like a plastic pryer.
Sebastian Szymański -
My Y700 has two harddrives. Is this the instructions for the primary hard drive or the secondary?
klobpries - Replica
It’s possible that the second drive is a M.2 drive. Both can be either. It’s suggested to use the faster drive for the system and the slower one for storage.
Would Samsung 1TB SSD 860 EVO work for the HDD replacement ?
chou jason - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 57
Tutti i Tempi: 10,310
