Salta al contenuto principale
Lenovo Ideapad S415 Touch Hard Drive Replacement
Cosa ti serve
  1. Lenovo Ideapad S415 Touch Hard Drive Replacement, Battery: passo 1, immagine 1 di 1
    • Flip laptop over bottom side up.
    • Locate the two battery release switches.
  2. Lenovo Ideapad S415 Touch Hard Drive Replacement: passo 2, immagine 1 di 1
    • Use your finger to push the battery release switch labeled "1." The red indicates that the switch is unlocked.
  3. Lenovo Ideapad S415 Touch Hard Drive Replacement: passo 3, immagine 1 di 1
    • Use your finger to push the battery switch labeled "2."
  4. Lenovo Ideapad S415 Touch Hard Drive Replacement: passo 4, immagine 1 di 1
    • Once both switches are unlocked, the battery will release.
  5. Lenovo Ideapad S415 Touch Hard Drive Replacement: passo 5, immagine 1 di 1
    • When replacing the battery make sure the two protruding holes line up with the slot.
    • Carefully remove the battery.
  6. Lenovo Ideapad S415 Touch Hard Drive Replacement, Hard Drive: passo 6, immagine 1 di 2 Lenovo Ideapad S415 Touch Hard Drive Replacement, Hard Drive: passo 6, immagine 2 di 2
    • Locate the five black screws on the back.
    • Use a Phillips #0 screwdriver to remove all five black 6 mm screws.
  7. Lenovo Ideapad S415 Touch Hard Drive Replacement: passo 7, immagine 1 di 2 Lenovo Ideapad S415 Touch Hard Drive Replacement: passo 7, immagine 2 di 2
    • Locate the three silver screws underneath the battery.
    • Use the Phillips #0 screwdriver to remove all three 4 mm screws.
  8. Lenovo Ideapad S415 Touch Hard Drive Replacement: passo 8, immagine 1 di 3 Lenovo Ideapad S415 Touch Hard Drive Replacement: passo 8, immagine 2 di 3 Lenovo Ideapad S415 Touch Hard Drive Replacement: passo 8, immagine 3 di 3
    • Locate the four rubber stoppers near each corner of the laptop.
    • Open up the stopper with your hands.
    • Use the Phillips #0 screwdriver to remove the 6 mm screws underneath all four stoppers.
  9. Lenovo Ideapad S415 Touch Hard Drive Replacement: passo 9, immagine 1 di 1
    • Open the laptop carefully.
  10. Lenovo Ideapad S415 Touch Hard Drive Replacement: passo 10, immagine 1 di 2 Lenovo Ideapad S415 Touch Hard Drive Replacement: passo 10, immagine 2 di 2
    • Locate the hard drive.
    • Use the Phillips #0 screwdriver to remove the two 4 mm screws that are holding the hard drive in place.
  11. Lenovo Ideapad S415 Touch Hard Drive Replacement: passo 11, immagine 1 di 1
    • The hard drive is now removed from the laptop.
  12. Lenovo Ideapad S415 Touch Hard Drive Replacement: passo 12, immagine 1 di 2 Lenovo Ideapad S415 Touch Hard Drive Replacement: passo 12, immagine 2 di 2
    • Once the hard drive is removed, locate the four screws that hold the metal frame to the hard drive.
    • Use the Phillips #0 screwdriver to remove the 4 mm silver screws on all sides.
Conclusione
Casey Zhang
Membro da: 02/06/19
315 Reputazione
2 Guide realizzate
UC Davis, Team S20-G5, Lore Winter 2019 Membro di UC Davis, Team S20-G5, Lore Winter 2019
UCD-LORE-W19S20G5
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 8
Tutti i Tempi: 557
