Salta al contenuto principale
Lenovo Ideapad Flex 4-1570 Touchpad Replacement
Cosa ti serve
  1. Lenovo Ideapad Flex 4-1570 Touchpad Replacement, Back Panel: passo 1, immagine 1 di 1
    • Shut down and unplug your laptop before you begin.
  2. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: passo 2, immagine 1 di 1
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: passo 3, immagine 1 di 1
    • Use a plastic opening tool to carefully pry off the back cover.
    • Remove the back cover.
  4. Lenovo Ideapad Flex 4-1570 Touchpad Replacement, Battery: passo 4, immagine 1 di 2 Lenovo Ideapad Flex 4-1570 Touchpad Replacement, Battery: passo 4, immagine 2 di 2
    • Disconnect the battery by using a plastic opening tool or your fingers to push the connector towards the battery.
    • Do not pry or pull on the socket itself or you risk damaging the motherboard.
  5. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: passo 5, immagine 1 di 1
    • Remove the three 4 mm screws using a T5 Torx Screwdriver.
  6. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: passo 6, immagine 1 di 1
    • Remove the battery.
  7. Lenovo Ideapad Flex 4-1570 Touchpad Replacement, Touchpad: passo 7, immagine 1 di 1
    • Locate the touch pad and remove the two 3 mm screws using a T5 Torx Screwdriver.
  8. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: passo 8, immagine 1 di 1
    • Disconnect the touch pad chip from the motherboard.
  9. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: passo 9, immagine 1 di 1
    • Disconnect the bronze piece of tape from touch pad and set it off to the side.
  10. Lenovo Ideapad Flex 4-1570 Touchpad Replacement: passo 10, immagine 1 di 2 Lenovo Ideapad Flex 4-1570 Touchpad Replacement: passo 10, immagine 2 di 2
    • Open the laptop and, with the assistance of the iFixit blue plastic tool, guide the touch pad through, it should come out on its own.
Conclusione
Isaiah Vang
Membro da: 10/04/18
669 Reputazione
6 Guide realizzate
UW Stout, Team S6-G6, Ogden Fall 2018 Membro di UW Stout, Team S6-G6, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G6
4 Membri
16 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 550
