Salta al contenuto principale
Lenovo Ideapad Flex 4-1570 Display Replacement
Cosa ti serve
  1. Lenovo Ideapad Flex 4-1570 Display Replacement, Back Panel: passo 1, immagine 1 di 1
    • Shut down and unplug your laptop before you begin.
  2. Lenovo Ideapad Flex 4-1570 Display Replacement: passo 2, immagine 1 di 1
    • Remove the nine 6 mm screws using a T5 Torx Screwdriver.
    • Remove the two 10 mm screws using a T5 Torx Screwdriver.
  3. Lenovo Ideapad Flex 4-1570 Display Replacement: passo 3, immagine 1 di 1
    • Use a plastic opening tool to carefully pry off the back cover.
    • Remove the back cover.
  4. Lenovo Ideapad Flex 4-1570 Display Replacement, Display: passo 4, immagine 1 di 2 Lenovo Ideapad Flex 4-1570 Display Replacement, Display: passo 4, immagine 2 di 2
    • Use an opening tool to remove the three hinge bezels.
  5. Lenovo Ideapad Flex 4-1570 Display Replacement: passo 5, immagine 1 di 1
    • Remove the four 4 mm screws (two on each hinge) using a T5 Torx screwdriver.
  6. Lenovo Ideapad Flex 4-1570 Display Replacement: passo 6, immagine 1 di 3 Lenovo Ideapad Flex 4-1570 Display Replacement: passo 6, immagine 2 di 3 Lenovo Ideapad Flex 4-1570 Display Replacement: passo 6, immagine 3 di 3
    • Attach a suction handle to the corner of the display, then wedge the blade of a Jimmy between the display and its housing.
    • While sliding the Jimmy around the perimeter, place opening picks in the gap you created at regular intervals.
    • Once you've worked around the perimeter, lightly pull on the suction handle while gently prying with an opening tool until the display releases.
  7. Lenovo Ideapad Flex 4-1570 Display Replacement: passo 7, immagine 1 di 1
    • Use a T5 Torx screwdriver to remove the six 4 mm screws (three on each hinge) securing the hinges.
  8. Lenovo Ideapad Flex 4-1570 Display Replacement: passo 8, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to remove the rubber stoppers in both hinges.
  9. Lenovo Ideapad Flex 4-1570 Display Replacement: passo 9, immagine 1 di 1
    • Remove the black foam over the black and white cords, to the left of the Wi-Fi card, using tweezers.
  10. Lenovo Ideapad Flex 4-1570 Display Replacement: passo 10, immagine 1 di 1
    • Disconnect the black cable near the fan using tweezers.
  11. Lenovo Ideapad Flex 4-1570 Display Replacement: passo 11, immagine 1 di 1
    • Remove the display from the rest of the computer.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 17
Tutti i Tempi: 272
