Introduzione
The laptop touchpad is a built-in mouse. If there is any dirt or debris in the crevices. the touchpad might be unresponsive. The touchpad could have been accidentally locked. Try cleaning and checking your settings, before removing your touchpad. If the touchpad is still unresponsive, this guide can help you replace the touchpad on your Lenovo IdeaPad 320-15IAP.
Cosa ti serve
Unscrew thirteen 6.5mm screws from the back panel with the Phillips #0 screwdriver.
Pull the CD tray out with the opening tool once all screws are removed.
Use the opening tool to pull the case off the laptop by prying up the back panel along the edges of the computer.
Disconnect the display cable by lifting the black tab of the ZIF connector with the opening tool and gently pulling out the cable.
Disconnect the two coaxial cables on the WiFi card by gently pulling up on the wires.
Lift up the screen brackets by prying upwards on them with an opening tool.
Remove the two 2.5mm Phillips #0 screws from the upper edge of the trackpad.
