Salta al contenuto principale
Lenovo Ideapad 320-15IAP Hard Drive Replacement
Cosa ti serve
  1. Lenovo Ideapad 320-15IAP Hard Drive Replacement, Hard Drive: passo 1, immagine 1 di 2 Lenovo Ideapad 320-15IAP Hard Drive Replacement, Hard Drive: passo 1, immagine 2 di 2
    • Using a Phillips #0 screwdriver, unscrew all thirteen 6.5 mm screws from the back panel.
  2. Lenovo Ideapad 320-15IAP Hard Drive Replacement: passo 2, immagine 1 di 2 Lenovo Ideapad 320-15IAP Hard Drive Replacement: passo 2, immagine 2 di 2
    • Remove the CD reader with an opening tool. It is possible you have to apply a substantial amount of force so watch your fingers while doing so.
    • Lift the cover using the opening tool on different spots along the side of the laptop.
  3. Lenovo Ideapad 320-15IAP Hard Drive Replacement: passo 3, immagine 1 di 1
    • Remove the hard drive by inserting your finger under the highlighted area, then pushing up then pulling left to remove the drive.
    • Remove the adapter from the drive, then insert the new drive into the adapter.
    • To insert the new drive, gently place it into the enclosure for the hard drive and push carefully into the SATA slot.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 61
Tutti i Tempi: 1,680
