Salta al contenuto principale
Lenovo Ideapad 320-14ISK RAM Replacement
Cosa ti serve
  1. Lenovo Ideapad 320-14ISK RAM Replacement, Prepare the equipment: passo 1, immagine 1 di 3 Lenovo Ideapad 320-14ISK RAM Replacement, Prepare the equipment: passo 1, immagine 2 di 3 Lenovo Ideapad 320-14ISK RAM Replacement, Prepare the equipment: passo 1, immagine 3 di 3
    • Disconnect the charger and turn off the equipment.
  2. Lenovo Ideapad 320-14ISK RAM Replacement, Remove optical drive: passo 2, immagine 1 di 3 Lenovo Ideapad 320-14ISK RAM Replacement, Remove optical drive: passo 2, immagine 2 di 3 Lenovo Ideapad 320-14ISK RAM Replacement, Remove optical drive: passo 2, immagine 3 di 3
    • Turn the device over.
    • With a Phillips screwdriver, remove the screw pointed out in the image.
    • Slide the optical drive outward until it is removed completely.
    • Set aside.
  3. Lenovo Ideapad 320-14ISK RAM Replacement, Opening the laptop: passo 3, immagine 1 di 3 Lenovo Ideapad 320-14ISK RAM Replacement, Opening the laptop: passo 3, immagine 2 di 3 Lenovo Ideapad 320-14ISK RAM Replacement, Opening the laptop: passo 3, immagine 3 di 3
    • Remove the 12 remaining screws. Set them aside orderly.
    • With a plastic spudger, release the tabs that are found below the optical drive.
    • Continues releasing all of the tabs at the edges until the base of the laptop breaks loose.
    • Set the base aside.
  4. Lenovo Ideapad 320-14ISK RAM Replacement, Remove the existent RAM: passo 4, immagine 1 di 3 Lenovo Ideapad 320-14ISK RAM Replacement, Remove the existent RAM: passo 4, immagine 2 di 3 Lenovo Ideapad 320-14ISK RAM Replacement, Remove the existent RAM: passo 4, immagine 3 di 3
    • You may skip this step if there is no RAM installed previously.
    • Locate and open the tabs on the sides of the RAM. This will cause the RAM to become loose and take a diagonal position.
    • Remove the RAM in the same diagonal direction.
  5. Lenovo Ideapad 320-14ISK RAM Replacement, Install new RAM.: passo 5, immagine 1 di 3 Lenovo Ideapad 320-14ISK RAM Replacement, Install new RAM.: passo 5, immagine 2 di 3 Lenovo Ideapad 320-14ISK RAM Replacement, Install new RAM.: passo 5, immagine 3 di 3
    • Insert translation here
Conclusione
Congratulations! You installed your new RAM memory. Now, reassemble the laptop by following steps 1, 2 and 3 in reverse and enjoy your upgraded laptop.
Un ringraziamento speciale a questi traduttori:
es en
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 94
Tutti i Tempi: 1,777
