Salta al contenuto principale
Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement
Cosa ti serve
  1. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement, Battery: passo 1, immagine 1 di 1
    • Ensure that your device is completely OFF before performing this procedure.
    • Unscrew the eleven 4 mm Phillips #0 screws on the bottom of the device.
  2. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 2, immagine 1 di 2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 2, immagine 2 di 2
    • Separate the back lid from the laptop using a plastic opening tool.
    • Lift the back lid off of the device.
  3. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 3, immagine 1 di 2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 3, immagine 2 di 2
    • Remove the battery connector from its socket by pulling the cable away from the hinge using your fingers or a plastic opening tool.
    • Do not pull on the socket itself or you risk damaging the motherboard.
    • Remove the two pieces of tape that are holding the battery down.
  4. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 4, immagine 1 di 1
    • Remove the five 4 mm Phillips screws securing the battery.
  5. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 5, immagine 1 di 2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 5, immagine 2 di 2
    • Lift the battery up and out of the device.
  6. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement, Wi-Fi Card: passo 6, immagine 1 di 1
    • Locate the Wi-Fi card.
  7. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 7, immagine 1 di 1
    • Disconnect the two wires that are connected to the Wi-Fi card by gently pulling them up.
  8. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 8, immagine 1 di 2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 8, immagine 2 di 2
    • Unscrew the one 4mm screw keeping the card in place.
  9. Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 9, immagine 1 di 2 Lenovo Ideapad 110S-11IBR Wi-Fi Card Replacement: passo 9, immagine 2 di 2
    • Gently pull the Wi-Fi card out of place.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 13
Tutti i Tempi: 1,234
