Introduzione
This guide will allow any owner of a Lenovo Ideapad 110S-11IBR to undergo the process necessary to remove and replace the webcam of the device. To do so, simply follow the given steps, starting with the removal of the back panel, loosening of the screen hinges, and eventually removal of the screen, followed by the webcam. Although the webcam can be removed without removing the screen, it is tricky to do so, and is not recommended. To reassemble, follow the steps in reverse order.
Cosa ti serve
Use a Phillips #0 screwdriver to remove the eleven 3.7 mm screws from the bottom of the Chromebook.
