Salta al contenuto principale
Lenovo Ideapad 100S-11IBY 11.6" Battery Replacement
Cosa ti serve
Panoramica Video
  1. Lenovo Ideapad 100S-11IBY 11.6" Battery Replacement, Battery: passo 1, immagine 1 di 1
    • Remove all 11 screws from the base of the laptop.
  2. Lenovo Ideapad 100S-11IBY 11.6" Battery Replacement: passo 2, immagine 1 di 1
    • Once the screws have been removed, lift the base out of the laptop. You may need something pointy to pry it up.
  3. Lenovo Ideapad 100S-11IBY 11.6" Battery Replacement: passo 3, immagine 1 di 2 Lenovo Ideapad 100S-11IBY 11.6" Battery Replacement: passo 3, immagine 2 di 2
    • Next disconnect the battery
  4. Lenovo Ideapad 100S-11IBY 11.6" Battery Replacement: passo 4, immagine 1 di 1
    • Next remove the four screws holding the battery in place.
  5. Lenovo Ideapad 100S-11IBY 11.6" Battery Replacement: passo 5, immagine 1 di 2 Lenovo Ideapad 100S-11IBY 11.6" Battery Replacement: passo 5, immagine 2 di 2
    • And your all done.
Conclusione
Altre 7 persone hanno completato questa guida.
Nick Myers
Membro da: 04/15/18
3.398 Reputazione
21 Guide realizzate
Un commento
YOU HAVE TO REMOVE THE KEYBOARD. First, the keyboard is glued with two sided tape so it feels like you are breaking something getting it off. It also has clips all around don't try to undo the bottom until last. Second, there are 3 screws under the keyboard that need to be removed. The third screw was hidden under a Lenovo label, thanks Lenovo. Thirdly, there is no need to disconnect the keyboard harness.
panellockout - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 9,239
