Salta al contenuto principale
Lenovo IdeaTab S2109A-F Camera Replacement
Cosa ti serve
  1. Lenovo IdeaTab S2109A-F Camera Replacement, Battery: passo 1, immagine 1 di 2 Lenovo IdeaTab S2109A-F Camera Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the tablet off before beginning this guide. It is dangerous to touch internal components while the tablet is on.
    • Place the tablet on its screen and use the opening tool to remove the back cover.
    • With the tool, place slight pressure on the tablet to pry the back panel off.
  2. Lenovo IdeaTab S2109A-F Camera Replacement: passo 2, immagine 1 di 2 Lenovo IdeaTab S2109A-F Camera Replacement: passo 2, immagine 2 di 2
    • Grab the battery and gently lift upwards. This will show a red and black coiled wire.
    • Pull the battery gently until the cord has no slack.
  3. Lenovo IdeaTab S2109A-F Camera Replacement: passo 3, immagine 1 di 1
    • Carefully hold the battery in one hand while your other hand's index finger and thumb grab the two wires nearest to their connection point.
    • Use your fingers to give a firm tug to the black and red wires, but do not yank them hard enough to damage the tablet.
    • Remove the battery from the device.
  4. Lenovo IdeaTab S2109A-F Camera Replacement, Removing the Camera Housing: passo 4, immagine 1 di 3 Lenovo IdeaTab S2109A-F Camera Replacement, Removing the Camera Housing: passo 4, immagine 2 di 3 Lenovo IdeaTab S2109A-F Camera Replacement, Removing the Camera Housing: passo 4, immagine 3 di 3
    • Remove the two 4 mm screws from the right side of the housing with the Phillips #00 screwdriver.
  5. Lenovo IdeaTab S2109A-F Camera Replacement, Unscrewing the system board: passo 5, immagine 1 di 2 Lenovo IdeaTab S2109A-F Camera Replacement, Unscrewing the system board: passo 5, immagine 2 di 2
    • Locate the long, L-shaped system board.
    • Copper runs most of this length.
    • Remove the ten 2 mm screws securing the system board with a Phillips #00 screwdriver.
  6. Lenovo IdeaTab S2109A-F Camera Replacement, Disconnecting the system board: passo 6, immagine 1 di 1
    • Flip the central latch with a large opening tool to expose a gold connector.
    • Gently pull the gold connector using the latch.
  7. Lenovo IdeaTab S2109A-F Camera Replacement, Moving the System board: passo 7, immagine 1 di 2 Lenovo IdeaTab S2109A-F Camera Replacement, Moving the System board: passo 7, immagine 2 di 2
    • Pull up the L-shaped board to disconnect the two connectors at the top and bottom of the board.
  8. Lenovo IdeaTab S2109A-F Camera Replacement, Disconnecting the camera: passo 8, immagine 1 di 2 Lenovo IdeaTab S2109A-F Camera Replacement, Disconnecting the camera: passo 8, immagine 2 di 2
    • Grab the camera connection with your index finger thumb.
    • Disconnect the camera by gently pulling on this wire.
Conclusione
To reassemble this device, follow these instructions in reverse order.
Timothy
Membro da: 01/30/15
301 Reputazione
3 Guide realizzate
USF Tampa, Team 17-3, Watkins Winter 2015 Membro di USF Tampa, Team 17-3, Watkins Winter 2015
USFT-WATKINS-W15S17G3
4 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 14
Tutti i Tempi: 341
