Salta al contenuto principale
Lenovo IdeaTab A2109 Speakers Replacement
Cosa ti serve
  1. Lenovo IdeaTab A2109 Speakers Replacement, Battery: passo 1, immagine 1 di 1
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 Speakers Replacement: passo 2, immagine 1 di 2 Lenovo IdeaTab A2109 Speakers Replacement: passo 2, immagine 2 di 2
    • Remove SD card if present.
    • Remove two black 3mm Phillips #00 screws.
  3. Lenovo IdeaTab A2109 Speakers Replacement: passo 3, immagine 1 di 2 Lenovo IdeaTab A2109 Speakers Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
  4. Lenovo IdeaTab A2109 Speakers Replacement: passo 4, immagine 1 di 2 Lenovo IdeaTab A2109 Speakers Replacement: passo 4, immagine 2 di 2
    • Remove seven black 3mm Phillips #00 screws.
    • The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
  5. Lenovo IdeaTab A2109 Speakers Replacement: passo 5, immagine 1 di 2 Lenovo IdeaTab A2109 Speakers Replacement: passo 5, immagine 2 di 2
    • Now you can take the battery out in order to either replace it or continue disassembling the device.
  6. Lenovo IdeaTab A2109 Speakers Replacement, System Board: passo 6, immagine 1 di 3 Lenovo IdeaTab A2109 Speakers Replacement, System Board: passo 6, immagine 2 di 3 Lenovo IdeaTab A2109 Speakers Replacement, System Board: passo 6, immagine 3 di 3
    • Remove three silver 1.8 mm Phillips #00 screws.
  7. Lenovo IdeaTab A2109 Speakers Replacement: passo 7, immagine 1 di 3 Lenovo IdeaTab A2109 Speakers Replacement: passo 7, immagine 2 di 3 Lenovo IdeaTab A2109 Speakers Replacement: passo 7, immagine 3 di 3
    Compra
    • Use tweezers to flip up the small black plastic locks on all four connections.
    • Carefully remove each of the exposed ribbons.
  8. Lenovo IdeaTab A2109 Speakers Replacement: passo 8, immagine 1 di 2 Lenovo IdeaTab A2109 Speakers Replacement: passo 8, immagine 2 di 2
    • Disconnect the two speaker connectors by pinching them with tweezers and sliding them out from the system board housing.
  9. Lenovo IdeaTab A2109 Speakers Replacement: passo 9, immagine 1 di 2 Lenovo IdeaTab A2109 Speakers Replacement: passo 9, immagine 2 di 2
    • Use tweezers or your finger nail to disconnect the camera attachment by flipping up the black rectangular connector.
  10. Lenovo IdeaTab A2109 Speakers Replacement: passo 10, immagine 1 di 3 Lenovo IdeaTab A2109 Speakers Replacement: passo 10, immagine 2 di 3 Lenovo IdeaTab A2109 Speakers Replacement: passo 10, immagine 3 di 3
    • Disconnect the HDMI connection with the system board
    • Use a plastic opening tool to pry up the system board, and you will hear a pop as it comes free.
    • Slide out the system board from its housing tab on the upper right corner.
    • Pull the board slowly away from the tab, and it will pop out.
  11. Lenovo IdeaTab A2109 Speakers Replacement, IO Board: passo 11, immagine 1 di 2 Lenovo IdeaTab A2109 Speakers Replacement, IO Board: passo 11, immagine 2 di 2
    • Remove the following two screws:
    • M 5.3 x 1.75 mm #00 phillips screws (silver)
  12. Lenovo IdeaTab A2109 Speakers Replacement: passo 12, immagine 1 di 1
    Compra
    • Once the screws are out, use the tweezers to pull the board straight out.
  13. Lenovo IdeaTab A2109 Speakers Replacement, Speakers: passo 13, immagine 1 di 2 Lenovo IdeaTab A2109 Speakers Replacement, Speakers: passo 13, immagine 2 di 2
    • Use the tweezer tool to flip up the three small plastic locks attached to the digital board.
    • Then, slide newly exposed ribbons out.
  14. Lenovo IdeaTab A2109 Speakers Replacement: passo 14, immagine 1 di 2 Lenovo IdeaTab A2109 Speakers Replacement: passo 14, immagine 2 di 2
    • M5.3 x 1.75 mm #00 phillips screws (silver)
  15. Lenovo IdeaTab A2109 Speakers Replacement: passo 15, immagine 1 di 1
    • Once it is unscrewed, use the tweezer tool to pull the digital board straight out.
  16. Lenovo IdeaTab A2109 Speakers Replacement: passo 16, immagine 1 di 1
    • Once the IO board and digital board have been removed you can access the speakers.
  17. Lenovo IdeaTab A2109 Speakers Replacement: passo 17, immagine 1 di 2 Lenovo IdeaTab A2109 Speakers Replacement: passo 17, immagine 2 di 2
    Compra
    • Using the tweezers, put on end underneath the speaker, and pull up. They will pop off fairly easily.
    • Repeat previous step for the other side.
Conclusione
Bcohen
Membro da: 04/14/14
436 Reputazione
2 Guide realizzate
Cal Poly, Team 7-19, Regan Spring 2014 Membro di Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
4 Membri
15 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 532
