Salta al contenuto principale
Lenovo IdeaTab A2109 IO Board Replacement
Cosa ti serve
  1. Lenovo IdeaTab A2109 IO Board Replacement, Battery: passo 1, immagine 1 di 1
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller indentation in the plastic cover that runs across the top of the device.
    • Wedge the plastic opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Lenovo IdeaTab A2109 IO Board Replacement: passo 2, immagine 1 di 2 Lenovo IdeaTab A2109 IO Board Replacement: passo 2, immagine 2 di 2
    • Remove SD card if present.
    • Remove two black 3mm Phillips #00 screws.
  3. Lenovo IdeaTab A2109 IO Board Replacement: passo 3, immagine 1 di 2 Lenovo IdeaTab A2109 IO Board Replacement: passo 3, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Disconnect battery power connector by pinching the connector with tweezers, and sliding it out of the housing.
  4. Lenovo IdeaTab A2109 IO Board Replacement: passo 4, immagine 1 di 2 Lenovo IdeaTab A2109 IO Board Replacement: passo 4, immagine 2 di 2
    • Remove seven black 3mm Phillips #00 screws.
    • The top right corner screw is underneath a yellow ribbon. Lift the ribbon up without disconnecting it and unscrew the screw.
  5. Lenovo IdeaTab A2109 IO Board Replacement: passo 5, immagine 1 di 2 Lenovo IdeaTab A2109 IO Board Replacement: passo 5, immagine 2 di 2
    • Now you can take the battery out in order to either replace it or continue disassembling the device.
  6. Lenovo IdeaTab A2109 IO Board Replacement, System Board: passo 6, immagine 1 di 3 Lenovo IdeaTab A2109 IO Board Replacement, System Board: passo 6, immagine 2 di 3 Lenovo IdeaTab A2109 IO Board Replacement, System Board: passo 6, immagine 3 di 3
    • Remove three silver 1.8 mm Phillips #00 screws.
  7. Lenovo IdeaTab A2109 IO Board Replacement: passo 7, immagine 1 di 3 Lenovo IdeaTab A2109 IO Board Replacement: passo 7, immagine 2 di 3 Lenovo IdeaTab A2109 IO Board Replacement: passo 7, immagine 3 di 3
    Compra
    • Use tweezers to flip up the small black plastic locks on all four connections.
    • Carefully remove each of the exposed ribbons.
  8. Lenovo IdeaTab A2109 IO Board Replacement: passo 8, immagine 1 di 2 Lenovo IdeaTab A2109 IO Board Replacement: passo 8, immagine 2 di 2
    • Disconnect the two speaker connectors by pinching them with tweezers and sliding them out from the system board housing.
  9. Lenovo IdeaTab A2109 IO Board Replacement: passo 9, immagine 1 di 2 Lenovo IdeaTab A2109 IO Board Replacement: passo 9, immagine 2 di 2
    • Use tweezers or your finger nail to disconnect the camera attachment by flipping up the black rectangular connector.
  10. Lenovo IdeaTab A2109 IO Board Replacement: passo 10, immagine 1 di 3 Lenovo IdeaTab A2109 IO Board Replacement: passo 10, immagine 2 di 3 Lenovo IdeaTab A2109 IO Board Replacement: passo 10, immagine 3 di 3
    • Disconnect the HDMI connection with the system board
    • Use a plastic opening tool to pry up the system board, and you will hear a pop as it comes free.
    • Slide out the system board from its housing tab on the upper right corner.
    • Pull the board slowly away from the tab, and it will pop out.
  11. Lenovo IdeaTab A2109 IO Board Replacement, IO Board: passo 11, immagine 1 di 2 Lenovo IdeaTab A2109 IO Board Replacement, IO Board: passo 11, immagine 2 di 2
    • Remove the following two screws:
    • M 5.3 x 1.75 mm #00 phillips screws (silver)
  12. Lenovo IdeaTab A2109 IO Board Replacement: passo 12, immagine 1 di 1
    Compra
    • Once the screws are out, use the tweezers to pull the board straight out.
Conclusione
Altre 9 persone hanno completato questa guida.
Brian
Membro da: 04/22/14
565 Reputazione
2 Guide realizzate
Cal Poly, Team 7-19, Regan Spring 2014 Membro di Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
4 Membri
15 Guide realizzate
6 Commenti
Great guide but make sure you REMOVE THE AUX SD CARD FIRST if installed or you will break the card and or card slot.
Other than that, no problems. I got the io board for $26 and I put it in for free.
James Bush - Replica
I need an io board for cheap... I might have to make a guide on how to attempt to repair io card without proper tools and a filed down soldering iron tip
Ember Leona - Replica
Thank you this was helpful. I think I fixed my screen flickers the LCD ribbon is under the battery and the ribbon from the volume board on the right I think that's related to the screen rotation lock. Those needed to be flipped up and reseated. Thanks
Thanks Very much
the guide is very clear
i have done the job successfully
omimh - Replica
Excelente guía. Muchas gracias.
Larry Pacheco - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 15
Tutti i Tempi: 4,924
