Introduzione
Use this guide to replace the digital board.
  1. Look at the back of the tablet and locate the speakers on top of the rear cover.
    • Look at the back of the tablet and locate the speakers on top of the rear cover.
    • There is a smaller plastic cover that runs across the top of the device.
    • Wedge the blue opening tool, under the middle of the cover as shown, then push up and the cover will pop off.
  2. Remove the following two screws: M3.0 x 3.0 mm #00 phillips screws (black)
    • Remove the following two screws:
      • M3.0 x 3.0 mm #00 phillips screws (black)
  3. Spedizione gratuita per tutti gli ordini superiori a 100,00 US$ o contenenti un Kit Attrezzi Pro Tech!
    Sfoglia il Nostro Negozio
    Mai riparato qualcosa? Questo è Genio.
    Condividi la tua storia di riparazione con #ImAGenius
    Siamo tutti Geni
  4. Once it is unscrewed, remove the rear cover This may take a little force to get off but with enough force it should pop right off Use a blue opening tool to pry it open
    • Once it is unscrewed, remove the rear cover
      • This may take a little force to get off but with enough force it should pop right off
    • Use a blue opening tool to pry it open
      • Slide the tool to one corner then grab another tool and slide it to the opposite corner
    • Pull the cover up and it will come off
  5. Use the tweezer tool to flip up the three small plastic locks attached to the digital board. Then, slide newly exposed ribbons out.
    • Use the tweezer tool to flip up the three small plastic locks attached to the digital board.
    • Then, slide newly exposed ribbons out.
  6. Remove the following two screws: M5.3 x 1.75 mm #00 phillips screws (silver)
      • M5.3 x 1.75 mm #00 phillips screws (silver)
  7. Once it is unscrewed, use the tweezer tool to pull the digital board straight out.
    • Once it is unscrewed, use the tweezer tool to pull the digital board straight out.
Conclusione
Altre 4 persone hanno completato questa guida.
Brian
Membro da: 22/04/2014
562 Reputazione
2 Guide realizzate
Cal Poly, Team 7-19, Regan Spring 2014 Membro di Cal Poly, Team 7-19, Regan Spring 2014
CPSU-REGAN-S14S7G19
4 Membri
14 Guide realizzate
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 17
Tutti i Tempi: 2,712
