Salta al contenuto principale
Lenovo IdeaTab A1000L Battery Replacement
Cosa ti serve
  1. Lenovo IdeaTab A1000L Battery Replacement, Battery: passo 1, immagine 1 di 3 Lenovo IdeaTab A1000L Battery Replacement, Battery: passo 1, immagine 2 di 3 Lenovo IdeaTab A1000L Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Be sure to power off your device before taking it apart.
    • Locate the small tab, marked with the lock symbol on the upper right hand of your IdeaTab above the volume control buttons. Use your fingernail to gently loosen this tab.
    • Use your Phillips #000 screwdriver and remove the 3.5mm screw and put it aside.
    • Using your blue, plastic opening tool, begin to gently pry the back panel away from the front panel starting by where the screw was.
  2. Lenovo IdeaTab A1000L Battery Replacement: passo 2, immagine 1 di 3 Lenovo IdeaTab A1000L Battery Replacement: passo 2, immagine 2 di 3 Lenovo IdeaTab A1000L Battery Replacement: passo 2, immagine 3 di 3
    • Locate the black back plate, above the battery.
    • Using a Phillips #000 screwdriver remove the 7 silver 3.5mm screws from the back plate.
    • Next, with the same screwdriver, remove the black 4.1mm screw.
    • Gently remove the back plate from the device.
  3. Lenovo IdeaTab A1000L Battery Replacement: passo 3, immagine 1 di 3 Lenovo IdeaTab A1000L Battery Replacement: passo 3, immagine 2 di 3 Lenovo IdeaTab A1000L Battery Replacement: passo 3, immagine 3 di 3
    • Use the plastic opening tool to disconnect the battery wires from the system board. Slide your opening tool under the white plastic piece and pry it up.
    • Again, use the plastic opening tool to loosen the battery from the device by lifting up on the battery on all sides. This will detach the battery from the adhesive.
    • Gently place the battery aside.
Conclusione
Altre 10 persone hanno completato questa guida.
Cal Poly, Team 7-21, Regan Spring 2014 Membro di Cal Poly, Team 7-21, Regan Spring 2014
CPSU-REGAN-S14S7G21
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 13
Tutti i Tempi: 22,956
