Salta al contenuto principale
Lenovo IdeaPad Z570 Screen Replacement
Cosa ti serve
  1. Lenovo IdeaPad Z570 Screen Replacement, Battery: passo 1, immagine 1 di 1
    • Place the laptop face down with the battery facing away from you
  2. Lenovo IdeaPad Z570 Screen Replacement: passo 2, immagine 1 di 1
    • Flip the right switch right-bound
  3. Lenovo IdeaPad Z570 Screen Replacement: passo 3, immagine 1 di 1
    • Hold the left switch.
  4. Lenovo IdeaPad Z570 Screen Replacement: passo 4, immagine 1 di 2 Lenovo IdeaPad Z570 Screen Replacement: passo 4, immagine 2 di 2
    • Push the battery forward lightly to remove it while holding the left switch.
  5. Lenovo IdeaPad Z570 Screen Replacement, Screen: passo 5, immagine 1 di 1
    • Open up the laptop with the screen facing you.
  6. Lenovo IdeaPad Z570 Screen Replacement: passo 6, immagine 1 di 2 Lenovo IdeaPad Z570 Screen Replacement: passo 6, immagine 2 di 2
    • Remove the two rubber square screw covers located in the left and right lower hand corners of the screen.
  7. Lenovo IdeaPad Z570 Screen Replacement: passo 7, immagine 1 di 2 Lenovo IdeaPad Z570 Screen Replacement: passo 7, immagine 2 di 2
    • Unscrew the two 4 mm screws behind the two rubber screw covers using the Phillips #0 screwdriver.
  8. Lenovo IdeaPad Z570 Screen Replacement: passo 8, immagine 1 di 2 Lenovo IdeaPad Z570 Screen Replacement: passo 8, immagine 2 di 2
    • Using the opening tool, pry open the plastic screen border, beginning with the upper right hand corner then working your way around.
    • Pry off the screen cover from the device.
  9. Lenovo IdeaPad Z570 Screen Replacement: passo 9, immagine 1 di 2 Lenovo IdeaPad Z570 Screen Replacement: passo 9, immagine 2 di 2
    • Remove the two 2 mm screws at the top two corners of the screen using the Phillips #0 screwdriver.
  10. Lenovo IdeaPad Z570 Screen Replacement: passo 10, immagine 1 di 2 Lenovo IdeaPad Z570 Screen Replacement: passo 10, immagine 2 di 2
    • Loosen the four 2 mm screws located at the bottom corners of the screen.
    • These screws cannot be removed.
  11. Lenovo IdeaPad Z570 Screen Replacement: passo 11, immagine 1 di 3 Lenovo IdeaPad Z570 Screen Replacement: passo 11, immagine 2 di 3 Lenovo IdeaPad Z570 Screen Replacement: passo 11, immagine 3 di 3
    • Tilt the screen forward gently.
    • Remove four 3 mm screws on the sides of the brackets holding the screen (two on the left side and two on the right side) using the Phillips #0 screwdriver.
  12. Lenovo IdeaPad Z570 Screen Replacement: passo 12, immagine 1 di 1
    • Lean the LCD screen face-down on the keyboard gently.
  13. Lenovo IdeaPad Z570 Screen Replacement: passo 13, immagine 1 di 3 Lenovo IdeaPad Z570 Screen Replacement: passo 13, immagine 2 di 3 Lenovo IdeaPad Z570 Screen Replacement: passo 13, immagine 3 di 3
    • Gently remove the adhesive covering surrounding the wires that’s connected to the back of the screen.
    • Disconnect the plug from the connection terminal.
    • Remove the screen completely.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 25
Tutti i Tempi: 1,070
